First RESET your router to defaults. for that press RESET button for 10 seconds RESET button is in back side of router. Then connect your router to computer with ethernet cable. Then you can access it with following link. http://192.168.1.1 or http://192.168.0.1 type user as "admin" and password as "admin" or blank or "password" Then you can see configuration page of router. Set WAN settings as your internet service provider settings. Enable DHCP . CLick on wireless and enable wi fi. If you want secure router then enable WEP security then add new code it is your password key for connect wi fi. Let me know if you need further assistance. Thanks.
To set-up and secure the wireless router from unauthorized access, follow these steps :- 1. Connect the wireless router to your computer with a LAN cable. 2. Start your browser and enter the router's configuration URL IP address. 3. Enter the router setup, login and password 4. Change the admin password 5. Go to the wireless settings and change the default SSID and turn off SSID broadcast. 6. Setup encryption key the strongest is WPA2 (if not then WPA). 7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router. 8. Record the settings you have made and keep it in a safe place and Save the settings. 9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router. 10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Was this helpful?
Yes
No
Popular Solutions for D-Link AirPlus DI-524 Wireless
my computer is upstairs and the router works fine on this one downstairs, I cant find the disc for...
(More)
my computer is upstairs and the router works fine on this one downstairs, I cant find the disc for my computer wireless card upstairs?
when i go through router setup it locks out my laptop. i need securitybut my own access at same...
(More)
when i go through router setup it locks out my laptop. i need securitybut my own access at same time.
After reseting my DI-524, accessing it yields screen telling me to update the firmware. I've tried...
(More)
After reseting my DI-524, accessing it yields screen telling me to update the firmware. I've tried to several time, but it just causes the router to lock up. I've tried reseting the unit again. And, yes I've cycled the power a few times ? no love. Y'all have any voodoo to solve this problem?
beste ik heb een probleem met mijn laptop kan niet meer op internet via mijn router hij en ik ben de...
(More)
beste ik heb een probleem met mijn laptop kan niet meer op internet via mijn router hij en ik ben de sleutel kwijt waar kan ik die terug vinden? en, of als ik 192.168.0.1 op de pc ingeef geraak ik niet in op dit adres wat kan ik doen gelieve in het nederlands aub mvg
