Gateway GT5220 PC Desktop
Problem for Gateway GT5220 PC Desktop
I need to know where the ribbons inside my tower
By schizokd on Nov 06, 2009
i need to know where the ribbons inside my tower run
Comments:
Nov 06, 2009
- all the cables inside the tower
Clarification Request
Posted by virtualhost on Nov 06, 2009
If you are referring to the SATA cables, these are connected from your motherboard to your hard disk. Can you elaborate what do you mean by your ribbons run?
Best Solution
posted on Nov 06, 2009
Very Helpful)
hozer88
Rank: Master
Rating: 91%, 7 votes
the only way to tell is to open the case, it's usually not very hard. mostly 2-3 screws or nobs on the back or some have a handle on the case you slide back and the side will come right off.
IF YOU DECIDE TO DO THIS: make sure you are properly grounded. you can buy a strap that has velcro one the end that goes around your wrist and an alligator clip on the other that you clip on the case, or (and i know this sounds wrong but it works), make sure your computer is turned off, but leave the cable plugged in. the round plug on the cable is a ground connection. once you take the cover off put your hand on the power supply or the frame before you touch anything inside the case. 1 static shock (like when you walk on carpet and shock someone) is enough to blow a motherboard, hard drive, ram chip, video card or basically any part in the pc.
you'll need at least 1 screwdriver , probably a small phillips head, to get the case off, a small bright flashlight, a small magnifiying glass wouldn't be a bad idea, and a friend to help wouldn't be a bad idea also. but basically all you can do is gently grasp the cables with your hand and trace where they go. one end will go to the device and one will go to the motherboard or power supply.
when i was teaching pc upgrade and repair i always told my students to get a piece of paper and draw a picture of where things were. on most motherboards if you look closely, (this is where the magnifiying glass comes in handy) plugs, ports, and slots are usually marked to tell you what plugs into that spot. just go slowly and take your time, don't pull on any thing very hard, the cables should move pretty easily, but a small tug in the wrong direction and you could unplug something. this is where the map come in handy.
also if you take any cards or chips out DO NOT touch the brass ends. this will leave grease on the ends and will start corrosion in the slots or on the chip or circuit.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Very Helpful)
Azraelsrl
Rank: Guru  Computer Hardware  Expert
Rating: 92%, 368 votes
There are no ribbons running inside your pc. The flat cables are there to connect the hard disks, floppy and the optical units to the motherboard.
The hard disk must be connected to the first socket on the motherboard (labeled ATA1). The blue connector of the cable goes to the motherboard the other head plugs into the device.
Was this helpful?
Yes
No
Solution #3
Not Rated)
dwane4444
Rating: 87%, 78 votes
Here is a link to an inside view of your computer, maybe this will help:-
http://support.gateway.com/s/CASES/WME1T493-001/WME1T493-001iv.shtml
Also a link to your user manual:-http://support.gateway.com/s/PC/R/1009151/1009151ul.shtml
Was this helpful?
Yes
No
Popular Solutions for Gateway GT5220 PC Desktop
Questions and Unsolved Problems for Gateway GT5220 PC Desktop
Do you recommend Gateway GT5220 PC Desktop?
Answer
Answer
install speaker in dell pc mine has no sound Logitech L S 11
Answer
Forgot admin password dell 1545 vista srevice pack 1
Answer
emits bang on heating The small oven on the deLonghi de926gwf heats and then gives a brief but... (More)
Answer
I have a cash management system Royal alpha 9155sc and I try to communicate with my PC via converter... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
