GE JE1460 1150 Watts Microwave Oven
Problem for GE JE1460 1150 Watts Microwave Oven
Microwave will not heat
By bullfighter5 on Nov 06, 2009
Solution #1
posted on Nov 09, 2009
Not Rated)
melba846
Rank: Wiz  Kitchen Appliances  Expert
Rating: 80%, 13 votes
Be sure all connections are made. Check outlet to be sure it is working properly. If all this works, and the machine does not heat, the megatron tube is bad and the machine needs to be replaced.
Was this helpful?
Yes
No
Popular Solutions for GE JE1460 1150 Watts Microwave
Questions and Unsolved Problems for GE JE1460 1150 Watts Microwave
Do you recommend GE JE1460 1150 Watts Microwave Oven?
Answer
Answer
metal pot took small amount of "paint" off back wall of microwave...still safe to use?... (More)
Answer
Microwave is 14 yr old in great shape. When I press on the latch the light inside comes on and the... (More)
Answer
GE microwave with turntable built into cabinet with trim kit. was working fine. Upon the next use... (More)
Answer
GE model : JES831WB 001 , FAULT NO.1- CLOCK RUNNING VERY SLOW ABOUT 13 SECONDS PER MINUTE, FAULT... (More)
Answer
JE1460WA001: You can enter cooking time etc and when you close the door and press start the m/w does... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE JE1460 1150 Watts Microwave...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
