Question about Canon PowerShot SD30 / IXUS i Zoom Digital Camera
My computer does not recognize camera software
For some reason, my computer all of a sudden does not recognize my camera's software when i plug it in to the computer. i was having trouble uploading before getting a "busy" message on the lcd, so i switched the connection to "pc connection." this is when the problem occured... help, please. I have had my Canon Ixus i zoom for over a year now and never had any problems downloading my pictures to my computer.  Then just today, I plugged my camera to my computer's USB and it registered as "new hardware".  When I tried to let it re-install automatically, I was asked to insert an installation CD.  I don't recall having a CD for my camera...or if I did, I can't seem to find it anywhere!  Do you have any suggestions what I might do to fix this problem so I can download my Christmas pics into my computer?  Thanks!
    Genius:
  • 2,985 Answers
Remove the software ans seeif if the compuyter recognises the camera on its own.
It should
There is no need for additional software to read a camera.
Posted on Jan 21, 2008
SOURCE:
I plug in my GEx5 to my computer but my computer doesn't recognize the camera
some cameras need to have the software installed on the computer, did you install the software? depending on the age of the computer some devics can be power hungry on usb ports and so will come up as unrecognised devices, ive expirienced this myself. or last but not least the camera has a faulty usb controller inside, there are a few reasons but the worst one is when its the computer is an old one and the usb ports just dont have enough power to run the camera.
Sep 06, 2011 | GE X5 Digital Camera
I can't get pictures uploaded for my kodak easyshare C813. I don't use an sd card, i just use the internal memory. Recently, i uninstalled the software (for some or another reason) and was just using...
When you plug-in the camera into the USB port, what is the message?
Do you see any pop-up on the lower right hand side of the screen?
Usually the pop-up is "Device is ready to use" or USB device unrecognized if the USB is not recognized
try the camera to other USB port
Oct 18, 2010 | Kodak Easyshare C813 Digital Camera
Unable to download pictures
I do know that sometimes a usb port will fail, for whatever reason, to recognize a device. It's happened to me before, and you can try a couple things. First, unplug and plug the usb port back in while it's connected to the camera. If the computer fails to recognize it, try you different usb ports, and the computer may respond. Aside from that, if you're running the XP or later versions of windows, you might try restoring your computer to a time before this problem occurred. Also, an update to Windows could have adversely caused this to happen, and restoring to an earlier date would hopefully reset the usb software's ability to recognize the port. Perhaps someone else will have suggestions if none of these things work, but that's the limit of my dealings with this problem. There's always the possibility that a hardware issue is at work here, but I hope not. If you do discover the port is bad, you can always get a hub and deal with it that way, leaving it connected to a known, good usb port. Just make sure you get a hub that is aided by a power source to relieve the computer from the burdon of powering up the hub. Good luck.
Apr 03, 2010 | Canon Cameras
Wont recognize camera says it s an apple
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 30, 2009 | Kodak EasyShare Z740 Digital Camera
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Canon powershot A560
You can restart your computer whilist the camera is connected so that when computer starts it quickly reads the camera and can boot from it.
Jul 04, 2008 | Canon PowerShot A560 Digital Camera
We have a Olympus fe-340 and all of a sudden when we plug it in to the computer it doesn't connect to download pictures. I usually turns on as soon as you plug it in and prompts you to up load. What can...
Sounds like your software no longer recognizes the device is plugged in. I would open the software program that you are using with the camera plugged in and try to find the upload/connect to camera command. You should be able to start the download from there. Hope this helps!
Jun 28, 2008 | Olympus Cameras
Quick Cam Pro 5000, isn't recognized...
Download the latest driver for your OS (i assume you are using windowsXP). Then when it asks you for the driver direct the location to the place where you have downloaded the latest from logitech.
Oct 17, 2007 | Logitech QuickCam Pro 5000 Webcam
I had the same problem. I am not in any way a computer guy. The problem was, I had been downloading the pictures from my Canon digital Camera onto a Dell desktop with windows XP through the front USB port for years, no problems. One day, it just stopped working, and I would get a "unknown device" message when I went into the device manager. If I tried to open up the software that came with the camera and clicked "start image transfer" , I would get "camera not found" Anyway, I googled it, and found on one forum somewhere someone suggested the culprit could be a newly downloaded or upgraded version of realplayer. So I went into realplayer tools, preferences. I turned off the automatic updates and message center and re-booted as instructed. I plugged in the camera, and it worked. If the person who posted that information is reading this, I thank you. I would have NEVER figured that out, and would likely be buying a new camera for no reason.
Oct 01, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Canon PowerShot SD30 / IXUS i Zoom Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
