Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Miele deluxe G542 - not draining
The dishwasher will go thru a full cycle but there is water pooling in the bottom. The bottom filter is clean. Any ideas? Thanks
  • Anonymous Apr 24, 2008
    water pools in bottom of dishwasher. Filter is clean.
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 3 Answers
SOURCE: Intake/drain light blinking on Miele G841 dishwasher
I cleaned out the drain pump and non-return valve on my Miele G658/858 and that fixed the problem. The G841 may have similar parts. It's easy to do. In order: 1. Turn off washer. 2. Remove the triple filter (the basket on the bottom of washer with the little handle. Turn the handle and remove) rinse out and set-aside. 3. Remove the standing water. I used a wet vac to remove the standing water from the bottom of the machine, but you can scoop it out also. 4. Tilt the locking clamp (tilt left) to the side. (this is a metal wire covering the white plastic valve. This valve is to the right of the triple filter basket.) 5. Pull out the non-return valve and rise will under running water. You may have to wiggle the valve a little. Pull straight up and out. 6. The drain pump is beneath the non-return valve. (it has a little plastic propeller, like a paddle wheel, inside) 7. Spin the propeller several times in both directions to make sure it's clear. ( I used the shop vac with a small hose attachment to clear the drain above the propeller compartment) 8. Carefully refit the non-return valve and secure it with the locking clamp. 9. Refit and lock the filter in place.
I haven't had a problem since and my dished are much cleaner- The problem must have been coming on for a long time.
Hope this helps,
Susan
Posted on Oct 08, 2008
SOURCE: Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Posted on Mar 22, 2009
  • 636 Answers
SOURCE: Dishwasher will not go thru wash cycles
if the water is not draining at all in any of the cycle it is probably the discharged line at the bottom of the pump has become blocked. there is an access panel at the bottom of the dishwasher which will allow you access the line. take the line off of the fitting , use a set of vise grips to remove the fitting from the base of the pump.You will probably find corn or rice lodged in the diaphragm within the fitting, remove debris and reinsert the fitting and hose. Hopefully this is helpful to you.
Posted on Jul 09, 2009
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
Ge dishwasher not cleaning dishes and leaving debris behind
check for corrosion or debris in the water jets clean if necessary
Mar 11, 2012 | Dishwashers
Recently there's been a white coating on dishes. Has to be scrubbed off manually or soaked in a vinegar/water solution. I flushed out the rotating arms to be sure water flows thru & it does. Checked...
use any brand of dishwasher cleaner from a local store and run your dishwasher with it.I would also recommend that a calcium lime and scale remover be ran through your dishwasher to clean it out.
this may have to be done a couple of times.
Jan 16, 2011 | Kenmore Dishwashers
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
There is a pool of water in the bottom of the dishwasher...just bought the house, no idea what the problem is....draining issues?
the filter in the bottom of washer iss full of crud.. it pulls out so you can clean it.. do this and get a bottle of dishwasher cleaner and run your washer on a hot cycle with just the cleaner in and it should be fine afterwards
Dec 14, 2009 | GE Dishwashers
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher water draining????
Make sure the odor is coming from the dishwasher.
Pull the bottom basket out and check for food that might be stuck in it. And check for food particles in the bottom of the dishwasher.
Then pour some baking soda into the dish liquid compatment. Run it through a complete cycle. This should deodorize and clean the dishwasher. i hope it helps. Please remember to leave rating.
Jul 19, 2009 | GE 24 in. GLD5860LSS Stainless Still...
Hotpoint BF162............. Water left, not draining
Open the bottom panel of the washer and see if it is full of water, if it is drain it away and clean all of the filters inside the washer and reset.
Mar 04, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
doy you hear any sound from either in the wash cycle
Feb 11, 2008 | Dishwashers
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
547 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
