Question about Sewing Machines
Sewing machine I have a euro-pro model 9101, This is the second time using it. The needle broke, I replaced it, now it wont work, I checked the bobbin holder for tangled thread, there was none. Its like the machine has frozen up. I cant even turn the wheel on it. Please help to solve this problem.
While I don't have specific solution for your problem, I have a similar problem with my "Euro-Pro 9101. My needle keeps breaking and it hits the needle plate. The needle plate is now very rough. Does anyone know what the solution might be?
Posted on Jan 24, 2008
  • deba Oct 22, 2013
    needle might be the wrong size -- might even be put in backwards -- not all sewing machine needles are able to be used in any sewing machine
Can I use a double needle in the euro pro model 9101?
Most all machines will take a double needle
Apr 26, 2015 | Sewing Machines
Can I use a magnetic pin holders by my Euro-pro 9101 sewing machine?
I use a pin holder that has magnets by electronic sewing machine all the time
Sep 20, 2014 | Euro-Pro Sewing Machines
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I have a euro- pro model 385x. Every time I try to sew, the needle jams and the bobbin is surrounded by thread. I have tried loosening the bobbin as well as tightening it but to no avail. I get a big...
The problem is likely the threading. Double check the threading, look twice or three times at the diagram. Even me, a tech sometimes threads a machine or serger wrong.
Jan 17, 2011 | Euro-Pro 473
Needle will not pick up bobbin threat
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
May 31, 2009 | Euro-Pro 473
Friends broke needle on my euro pro multi stitch sewing machine.
According to
Where can I buy new needles?
Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
has all the information including a downloadable manual (pdf file)
Jan 24, 2009 | Euro-Pro 9120 Computerized Sewing Machine
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
157 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
