Question about Samsung SGH-E900 Cellular Phone
Memory card problems for sgh-e250
I put my samsung memory card in my motorola and put it back cause it did't work and now i can't view my files on my memory card at all it always says not allowed.Wat do i do
  • Chris83702 Jun 08, 2008
    So, what is the technical solution? I see that someone has posted that a tech may be able to easily fix it .... do tell. Thanks, Chris.
Samsung will only read 2gig or lower memory card
Posted on Aug 26, 2008
Hello - I had exactly the same problem. All I had to do was keep the memory card in the phone as normal but turn the phone off and on again. Try it, I hope it works for you.
Posted on Jan 27, 2008
  • 192 Answers
It seems hardware problem which can be solved easily but by the skilled technician. If u r not then will be better to approach to nearby technician as it is internal problem.
Posted on Jan 06, 2008
File error appears on screen when viewing pkotos
can have different causes. To many pictures on the memory card card is full. From the last picture file name ends with 999 or 9999.
Or there was an error while writing a picture to the memory card, caused by a power failure.
I would put the card in an external memory card reader and try to put all pictures in a folder on the computer. Then format the card FAT 32 or FAT 16 and then put it back in the camera. When switched on, first format the card again, in the camera, to make sure the camera can work with the card and the format.
Success.
Apr 19, 2015 | Cameras
Having trouble with memory card for Samsung Note 2
the first thing i would try? move the apps back into phone memory out of the sd card.maybe put the wifi back on phone memory,shut the phone off,remove the battery,put it back in & restart phone.it may take a minute or two for the sd card to mount.
then to "my files" (under apps on home screen ).choose external memory.pick wifi,tap the top right button. you will see options.pick "move".pick "device storage".that should put it back on the device.turn wifi on & see if it works. (P.S-always before removing sd card,pick "storage" on your menu. you will see the option to
"unmount".be sure to do this every time before removing sd card.
Apr 03, 2015 | Samsung Galaxy Note 2
Samsung PL100 - strange problem
Put the card back into the camera and format it.
In the future, always format the camera after you finish download your pictures, instead of deleting them.
Jun 03, 2012 | Samsung PL Cameras
Sgh s3310 memory card not recorized ple solution
Hi hitendra_sin,
Try these steps:
Remove memory card and plug it to computer via card reader and check if it is able to reade the details
If it is successfully read by the computer, then take a back up of entire memory card.
Then format the entire memory card.
Check if it is recognized. If recognized, remove and plug it back to computer and copy only the required file to memory card like music, pictures and videos.
If not recognized, you will loose the data, try reformatting the memory card and use as new.
This should work.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | O2 Samsung SGH-E250 Cellular Phone
Hello I am having samsung GT-E1410 mobile. I am
SOLUTION TO RECEIVING FILES ON YOUR MEMORY CARD.
You cannot receive files on your memory card directly.
You are to receive it on your phones memory, then you move it to you memory card.
You ensure your phones memory is totally empty so you can receive your incoming files.
SOLUTION TO SEEING YOUR MAIL SENT
Go to messages,
select the message settings,
select the message sending option,
Select save and send.
once this is done, you will be able to view your sent mails in your outbox.
Take care
Jun 20, 2010 | Cell Phones
Whenever i try to download games on my SGH-e250 it says memory full please delete games but i dont have any games
Try buying a memory card (if you don't have one already) and moving some of your other files onto the memory card. That should free up some memory then try downloading the game again and it should have enough memory, Hope this helps. :)
Apr 16, 2010 | O2 Samsung SGH-E250 Cellular Phone
Memory Card Not detected in My MOTOROKR E6
if i gave master reset.. it's asking for Security code. I don't have that code. How to set it.
Jun 30, 2009 | Motorola Mobility ROKR E6 Smartphone
MEMORY CARD SLOT FOR N70 CAN'T READ / CANT TRACE MY MEMORY CARD
your card may need to be formatted for use in the phone. The phone supports FAT32 file system go to Menu - Tools/Setting - MemoryCard - Options - Format Mem Card and click YES
WARNING: Back up you card on your computer first because formatting you will lose your contents
Jun 19, 2009 | Nokia N70 Cellular Phone
Need help in getting my phone to reconize the memory card
Try formatting the card.
Put the card into your computer so you can view it and everything on it. Take all the files off the memory card and store them someplace on your computer.
Go to MY COMPUTER, right click the memory card and click FORMAT. Follow the directions and make sure QUICK FORMAT is NOT ticked. Then click format and give it a few minutes.
When it is done, put the memory card into your phone and see if it recognizes it now.
IF IT DOES, put the card back into your computer and put the files back onto the card. Then put it back in the phone. Should work now, if not, there is a defective file on the card and needs to be found because its interrupting the the phones processing.
IF IT DOESNT, try another memory card. The current card could be defective. If the phone still doesn't read the new card, the phones card reader is defective and needs to be sent to your phone provider to be fixed.
Hope this helps!
Have a nice day!
- Neal
Apr 27, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
139 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
