Sanyo DP42746 42 in. Plasma Television
Problem for Sanyo DP42746 42 in. Plasma Television
Power comes on but turns off, when back is removed
By yeethe1 on Nov 06, 2009
Power comes on but turns off, when back is removed the light on the power unit flashed 12 times, defined as D12V problem.
Solution #1
posted on Nov 06, 2009
Not Rated)
mikeoldfield
Rank: Guru  Televisions & Videos  Expert
Rating: 96%, 24 votes
So the 12V power supply is either not there (faulty power board) or is shorted by whichever board it is passed to.
I do not know this particual Sanyo, but I know what I'd do - I'd open and see at the power board which of the output cables carries 12V; they are most commonly labelled on the power board, right next to the output pins.
12V is usually power going to the audio amplifier and sometimes to tcon (LCD controller) of even the main board , but it won't go to to the ysustain - the other apparently large board when you open the TV.
Of all listed I'd say only the audio amplifier is likely to short...all others are possible, but highly unlikely.
BTW what do you mean "but turns off, when back is removed"?
Was this helpful?
Yes
No
Popular Solutions for Sanyo DP42746 42 in. Plasma
Questions and Unsolved Problems for Sanyo DP42746 42 in. Plasma
Do you recommend Sanyo DP42746 42 in. Plasma Television?
Answer
Answer
the problem is it wont come on or say anything no sound no power. the wall plug is good.is it a fuse... (More)
Answer
I have a remote I need the tv code for santo tv to program it into the remote
Answer
sanyo 52 inch plasma hd the tv has started consistently blinking when you turn it on.
Answer
I have a 46" sanyo plasma and the screen will go have black shadows pop on and off on half the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sanyo DP42746 42 in. Plasma...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
