Keyboards and Mice
Generic problem for all Keyboards and Mice
Keybard keys popped off, how do I put them back on
shared by 2 users
posted by dihawaiian on Jan 05, 2008
2 of my keys popped off
Comment posted on Jan 06, 2008
I still don't understand, I guess I am not a fix it person.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by dsadd on Nov 09, 2008
I have a similar problem, as I no longer have two of my keys, so I need to find or purchase those keys and then put them back on. Help !!!
Solution #1
posted on Jan 05, 2008
Thanks for Trying (70)
BggFixya
Rank:Guru Guru
Rating: 87%, 109 votes
On some keyboards, the key is locked to a X configuration of wires, that clip into the bottom of the keys. Problem is, when you press down on the keys, to remount them, the "X" spreads out to wide. I solved this by straightening out a heavy paperclip. A little bend in it, and you place it under the apex/joint of the "X" so it don't collapse. Then just press the key down firmly on it, and pull out the paperclick.
Comment posted on Jan 07, 2008
Hi Di!
Here are some photos explaining one way.
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/comment-page-2/
If the two white clips are still attached to key, they will hang down, forming the "X". Put the Cuustom tool, Key installer, (paperclip, formed into a "L", under the key, forcing the "X" to stay extended. That way the legs of the "X" will stay extended, and not spread so wide.
Good luck
Rating Locked! (?) dihawaiian has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on keybard keys popped off, how do I put them back on:
I don't want to Accept this solution
Solution #2
Not Rated (0)
bbtoast
Rank:Guru Guru
Rating: 91%, 204 votes
This should not be a problem that you cannot fix!
All you need to do is look at the bottom of the keys that fell off, and look at the "peg" on the keyboard so that you can see how it goes in. Take the key between your fingers, and slowly pop it into place. You may need to press it with a little force. Make sure you put the letter on "right side up" DON'T Laugh, I've done it before!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Keyboards and Mice problems?
Microsoft & Wireless Notebook Optical Mouse...
my Microsoft wireless notebook optical mouse is not...
Microsoft Wireless Laser Mouse 6000 v2.0
I have no use of any functions on my rt mouse...
Microsoft Wireless Optical Desktop Elite...
I changed the batteries on my keyboard, pressed the button...
Microsoft WIRELESS LASER DESKTOP 4000...
my backspace key seems to be broken - it sticks in the...
Edirol PCR-30 32-key Midi Keyboard...
I have an Edirol PCR-M50 MIDI Keyboard Controller, and I...
Loading problems.
Repair Service
Find Keyboard and Mice Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
