Kenmore 64802 Top Freezer Refrigerator
Problem for Kenmore 64802 Top Freezer Refrigerator
The refrigerator part does not get cold. The
By imbackmk on Nov 06, 2009
The refrigerator part does not get cold. The freezer does but not as cold as I would like it to be, but the main part is not cold at all. I have move the cooling dial to all different settings and nothing. What is wrong with it?
Solution #1
posted on Nov 06, 2009
Somewhat Helpful)
nanbuenbrazo
Rank: Wiz  Refrigerators  Expert
Rating: 79%, 164 votes
to possible reason.
1. Under charge, your refrigerant gas is not enough to accumulate or produce ice, reason possible leak along the pipe line all the way to the back near the compressor (signs: oily part)
cause: Vibration or use of sharp hard object in removing frozen food or ice
2. Lost Compression (Motor compressor) failure to produce enough pressure to accumulate ice.
cause:un stable power distribution or flactuatuion of electric current
or old age of the compressor
Was this helpful?
Yes
No
Popular Solutions for Kenmore 64802 Top Freezer
Questions and Unsolved Problems for Kenmore 64802 Top Freezer
Do you recommend Kenmore 64802 Top Freezer Refrigerator?
Answer
Answer
freezer not freezing but lower compartment is cool Kenmore top cabinet is freezer
Answer
Neither the top of bottom are getting cold. Thought it was the thermastate, turned it up and it... (More)
Answer
frozen water in bottem of freezer--turned ice maker off--no water freezing--when turned back on, no... (More)
Answer
We're leaving it for the winter in a closed unheated cottage (in Michigan). Is it better to prop the... (More)
Answer
why is water leaking into the bottom of my refrigerator
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 64802 Top Freezer...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
