I had a similar problem after a virus attack on yahoo messenger ..it affected my cd-rom driver ...and pretty much all the rest ..but first it ...I tried to reinstall but no luck ...so ...until I reinstalled the pc with a clean install I mean from the disk and formatting the C partition ...I didnt get anything ..but it worked after ...so ..this is what I suggest too .. but first I suspect it to be disabled too ...so ..restoring factory defaults in the Bios will be a good thing too... also you might try to look for it in the hardware manager ...and try to install it ..by downloading its driver ...and than run the wizard for installing from there ...just click update driver ...if it will be in yellow with an ask sign it means that has no driver .. but ..reinstalling clean its still the right way ...Keep in mind that installing from a recovery stored in another partition ..might not do the job ..cause either it sees it disabled...or ..the virus that cause it ..do not dissapear ..and restores the damages..
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
thank you
" - angeeandkenn
Popular Solutions for Acer Aspire? T180 PC Desktop
What are the problems using a JNC92 motherboard with a ADPE4S-PB daughterboard? I am connecting 4 x...
(More)
What are the problems using a JNC92 motherboard with a ADPE4S-PB daughterboard? I am connecting 4 x SATA 1TB disks in RAID 5. I can see the disks in the BIOS. I can see the disks when I look at the properties of another disk in the "Hardware" button, and am told they are working correctly. But cannot access them in Windows XXP Pro SP2. Can only see and access them as JBOD not RAID. Why? Hywel Davies
no sound no picture already ruled out hd converter as the problem . only 3 yers old. what are the...
(More)
no sound no picture already ruled out hd converter as the problem . only 3 yers old. what are the TERMS OF USE before I agree
