Question about Olevia LT37HVS 37 in. LCD HDTV
Audio Problems When I have a comcast/motorola cable box connected thru the component inputs the sound will intermittently either sound scrambled/garbled or has a loud tone. This problem also occurs with a dvd connected in the component inputs too. Also if you select 720p or 1080I in the service menu on the motorola box there is a loud popping sound thru the tv speakers even if the audio input cables are disconnected. It seems the popping is from the Y input. If you switch the resolution to 480i or 480p it seems to go away. Any ideas where the problem is?
  • 1,067 Answers
Well dvd player is only 480 i ok not 720 unless its blue ray so dont even do that coupont cables usallly 480 also with comcast outs do u have hd then use one with hdmi outs ok coxal digtal cable works great also better rcas
Posted on Jan 06, 2008
  • nick helpap
    nick helpap Jan 07, 2008
    turn off dobly digital sound cuse tv cant handle that ok in comcast box audio settings use pcm
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
I'm trying to hook up my reciever up to my new flat screen any help as far as what cables I need, I will also be putting a dvd player on as well. I have comcast cable also, I've been told I need to get a...
This is posted under the Sony STR-DE685 heading, so I assume that's what you have. (If not, your receiver may have other hookup options available.) It might help if you download the manual if you need a copy from Sony's site here. It details all the rear panel connections.
This receiver doesn't have HDMI connections, so you'll need to make your connections using RCA cables It doesn't pay you to get an HD cable box if you're planning on connecting it through the receiver.
Output to the TV is very simple. Use a component video cable to go from the component monitor output on the receiver to the TV's component input. Then switch the TV to that input, turn off its speakers and listen to the sound through the receiver. Only one cable going to the TV that way.
Inputs will need separate audio and video connections since there are no HDMI connectors. Use the component video connection for your DVD player for the best video quality. The DVD/LD input offers those jacks. You can connect your cable box to the VIDEO 2 input using component video connections (if the box has those outputs) or composite video. Then the video and audio from the box will run through the receiver as well.
If you want to get a new HD cable box, you'll need to run a cable from its HDMI output to an input on the TV, and switch the TV to that input to watch the box. You can still run the audio signal through the receiver though. That will add one more cable to your hookup, and you'll have to remember to switch inputs.
Hope this helps. Thanks for using Fixya!
Jan 26, 2010 | Sony STR-DE685 Receiver
How to connect tv to comcast cable box
If you only have the comcast receiver and a TV, take the input (wire from outside the house or outlet on wall) and screw that onto the input of the comcast receiver. Take another wire (or RCA, component connecters or whatever means the box and TV provides) and go from the output of comcast receiver to the input of the TV. Set the TV input mode (on the TV itself or by the remote) to whatever mode you hooked up the cables to (video 1, aux, video 2, etc) and you should see a picture. From there use the comcast remote to change channel. If you use the round cable (rg56 or rg59) you will not need any other connections between the TV and the box. The video and audio are broadcast on the same line. If you use RCA (yellow red white) connectors, yellow is video, white and red are audio) you will need all three wires from comcast receiver to TV. I hope this helps and good luck!
Nov 18, 2009 | Audio Players & Recorders
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Olevia LT37HVS 37 in. LCD HDTV Logo
179 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
