Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How to install my multi function center
Trying to install this machine, won't let me get past the connect the USB window
    Master:
  • 619 Answers
Install CD together w/ that printer / open control panel / press printer icon for printer installation , just follow the instruction.After finish on it open device manager to asign the printer then ok.
Posted on Jan 05, 2008
  • 758 Answers
That means that windows doenst recognize that you have your usb connected...try a port that is in the back instead of the front...also plug your device before you run the program..
I downloaded printer driver for brother mfc240c, but even after install, I get a message that says the driver isn't installed.
Open the printer and scanners folder an delete all the devices (Brother Printer, Brother Fax, Brother PC-Fax if installed). Point to device an right click the mouse button.
Restart the computer.
Download the software from Brother Solutions Center. Download the whole suite not just the drivers. Make sure you select the software that is compatible with your version of the OS :Windows 7 32 bits, Windows 7 64 bits, Windows 8 32 bits, etc.
Install the software. If you are going to use a USB cable to connect the MFC to the computer, install a local USB printer. If you are going to use Ethernet network cable, install a wired network printer, and if wireless connection then install a wireless printer.
If you have problems finding or attributing an IP address to your printer (for Non-USB connections) there is Brother program that helps you attribute an IP address. You will find it on the same page as the software suite on Brother's site.
Nov 07, 2013 | Brother Multi-Function Center MFC-240C...
I hve windows 7 and am trying to set up brother mfc-665cw wireless is it supported
Try installing the software that shipped with the MFC. If you have problem installing the software on Windows 7, you can go to the Brother Solution Center and download the latest version. If the Optical character Recognition software is not installed with the suite downloaded from the web, you will have to use the CD shipped with the machine to install it.
You will need to use the software to add a new printer to your network.
Aug 27, 2011 | Brother Multi-Function Center MFC-665CW...
How to scan on brother mfc-240c
Two methods are:
1) Insert a USB Flash drive into the machine.
Select the SCAN function.
Follow the prompts on the display (asking for filetype, etc)
2) With the machine directly connected to a PC via a USB cable you can use the Brother scan software that came with the machine. If you do not have the disc that came with it you can get the software from their website.
Here's a link to Brother's SCAN support section
May 31, 2011 | Brother Multi-Function Center MFC-240C...
I need control center for my brother mfc-240c
You can download that from www.brother-usa.com. Look near the top-right corner for the blue box labeled Service & Support, and click "Downloads." You'll have to select your machine's family (Multi-Function) and model, then your computer's Operating System. For most machines, Brother offers a choice of barebones drivers or the complete package; you'll want the full package to get the Control Center.
Brother requires that you install the driver package before you plug the machine into your computer. If you have already plugged it in and let Windows try to install a generic driver or something, you may need to download and run a utility for uninstalling the machine completely before installing the package properly. That utility program is probably at the bottom of the page of drivers on the Brother site.
Apr 03, 2010 | Brother Multi-Function Center MFC-240C...
Problem with installation
First Disconnect your printer
Reboot the computer
Start the installation from CD
Connect the printer when you see the screen to connect the printer
Once you connect the printer correctly to the USB it will proceed with the installation
Oct 07, 2009 | Brother Multi-Function Center MFC-240C...
8870DW scan function does not work with macBook using USB
You must reinstall the software on the computer to which the printer is physically connected. i think u are using usb to connect to computer so to share it out u most buy printserver or use let the computer where its physically connected just to be on and u share there the computer to your workgroup computers
Dec 27, 2008 | Brother Multi-Function Center MFC-8870DW...
Scanner
Can you copy?
If yes, what windows system do you run and did you install the complete mfl-pro suite?
How do you connect the machine to the pc? Do you use a hub or did you connect it directly to the pc usb? The latter one is the right one for scanning.
Nov 19, 2007 | Brother Multi-Function Center MFC-240C...
USB CABLE FOR MFC 1770
This unit cannot be used as a printer unless you purchase a separate special interface This is from the Brother manual for your product. This was written some time ago and I'm not sure that it is still available. I did a search on Brother and found that they still offer it. Whether it still in stock or not I don't know. Their price is $99.00. Add to this the price of the thermal ribbons and it does not make a very efficient printer. You can purchase the optional Multi-Function Link® package (also called ?Missing Link?). Multi-Function Link® turns your fax machine into a multi-function center, by enabling you to use your fax machine as a printer and a scanner and to use it to fax messages from Windows® applications in your computer. The Multi-Function Link® option is for Windows® 3.1x and Windows® 95/98. Multi-Function Link® is available at most Brother retailers. If you cannot find it, you can order Multi-Function Link® directly from Brother. The item number is PCI-1. Wish I had better new for you. Ed
Jun 13, 2007 | Brother MFC 1770 All-In-One Thermal...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
