Blenders
Problem for Blenders
Generic problem for all Blenders
I have one of those
By fsusf_11 on Nov 06, 2009
I have one of those back to basics blender express machines and it will not come open. i've run hot water over it and cold water but the thing is the seal ring was missing but it still closed so i closed it and blended something in it and now it won't come open.
Comments:
Nov 06, 2009
- ive tried tapping it with things, i banged it on the ground and hard surfaces and that didnt work, about 20 different people have tried to open it. nothing has worked
Solution #1
posted on Nov 06, 2009
Somewhat Helpful)
gmillsy54
Rank: Guru
Rating: 89%, 279 votes
i suggest placing it into a table vice and just crank the hell out of it!
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
dwane4444
Rank: Guru
Rating: 87%, 75 votes
The seal ring probably stopped the blender from tightening to far. It is a good idea to warm the blender but you can also try tapping it with a small piece of wood or similar as you try to open it. I think it may just need a bit more force to get it open. Be aware that it could break - but you can't use it at the moment anyway!
Comments:
Nov 07, 2009
- Just a thought - is the blender one of those that has a left hand thread on the blender jug? In other words to undo it you have to turn it the opposite way to normal.
Nov 07, 2009
- Hi again - no it does not have a left hand tread! I found the manual on line at this link:-
http://dl.owneriq.net/5/5aa17631-9328-1554-9995-481a49228b31.pdf
It has the following instructions to remove the jug, Note the "unlock".
1. Unlock the mug from the motor base and then flip the mug
over.
2. Turn the blade base counter-clockwise and remove it from
the mug.
3. Screw the mug lid firmly in place on top of the mug.
Was this helpful?
Yes
No
Popular Solutions for Blenders
Questions and Unsolved Problems for Blenders
Answer
pour spout broken on back to basic sp smoothie 600
Answer
put together push button to chop up stuff the light lights for on but doesnt start
Answer
Where can I find a part for a back to basics blender model 3053678. Thank you for your assistance
Answer
The impeller on my Smoothie Maker only turns when nothing is in the blender. with any load, the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Blenders:
Top Blender Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
