Question about Durabrand DVD-1002 DVD Player
CC? I can not find CC on my DVD player, any help?
  • PepperSlone Jan 09, 2008
    I bought a new jeopardy game that requires cc be turned on. The game place said DVD-1002 had cc, but I can't find it.
  • 3 Answers
Try the subtitle button...if you have the remote for the DVD-1002 it should be located on the lower right hand side of the remote....right to the right of the 3
Posted on Jan 10, 2008
6ya staff
SOURCE:
I can't shutoff closed caption. Tried using menu on the tv and the remote
Both a cable box and and a DVD work the same. The CC is included with the picture sent to the TV. The only time the TV controls and activates CC is when you are using an antenna. If the CC is not turning off then it is likely that you are connected to a cable service and the settings in the cable box need to be changed.
If you have a cable service remote then there is likely a button dedicated to closed captions. If not you will need to go into menu settings of the cable box and deactivate the closed captions. (cc)
Even though the DVD is integrated into the TV the settings for the DVD are separate. If while playing a DVD CC are on it is not the TV settings but the DVD so as the cable box the same is true.. You will need to go into menu settings of the DVD player and deactivate.
Hope this helps?
May 22, 2016 | Sylvania 32" Lcd Hdtv Dvd Combo - 720p...
Will this dvd player play closed caption dvd's?
It depends on the TV.Go to your TV menu and look for cc on or off. Also it depends on the movie or TV show programming. Some movies might not show cc and offer subtitles, use subtitles if your TV does not have the cc option.
Feb 21, 2016 | Televison & Video
CC (closed caption) won't show up on DVD movies for LG 42CS570 hooked up with standard DVD player (not Blu-ray). How can I fix that?
Subtitle setting is in the dvd setting not the tv, If the DVD would have CC it would be on the case, CC is encoded in to the tv signal
Mar 01, 2014 | LG 37LP1D 37 in. LCD Television
I can't get subtitle to turn on. Zenith DVD player to play movie with Subtitle
What you want is Closed Captioning. It has nothing to do with subtitles. If you turn off the speakers in your TV, the CC should appear after a brief pause. If your TV is not equipped for CC, this approach won't work
Nov 11, 2012 | Televison & Video
A black box appears randomly on the tv screen
You should check to make sure that your CC (closed captions) are not set to a text mode. If your remote has a CC button, push it a few times until you see CC off or CC1, this should resolve the searching for text issue that you are experiencing.
Jul 26, 2011 | Toshiba LCDTV/DVD Player 19HLV87
How do you shut off the closed caption feature?
I do not know this dvd player, but on most anything with closed caption, you hit the cc button on the remote until you come to '0' or 'off'. As CC has about 6 channels it can use, but really only channel '1' is used. So you might have to cycle through the CC channels until closed caption disappears. Hope this helps. You might also have a setup menu on this DVD where you can control the CC.
Just cycle though it till you get to '0' or off, exit the setup menu.
Jan 07, 2011 | KLH DVD-221 DVD Player
Can not get closed captions on dvd to play on sony tv with captions on tv set on.
Hi, you might have to turn the CC feature off from your TV and select the CC feature from the DVD disc set up.Refer to page 35 of the owners manual to get the correct language caption on your disc(dvd): basically press the audio key on your remote control until the desired captioning appears.
Jun 21, 2010 | Toshiba SDV395 DVD Player/VCR
How can i remove unwanted subtitles the movie is in english and the sub titles ate very distracting
Usually, if the subtitles are from your dvd player, you can go to the main menu, select "languages" or "setup" (depending on the dvd), and find the subtitle option. You should be able to shut them off there in the menu. If the subtitles are there because of your tv, there should be a button labeled "cc" on your remote. If you press this key a few times, it should eventually read something like "cc off" on the tv screen. I hope this helps, and good luck! Sincerely, Der Strom
May 10, 2010 | LG DR-4912 DVD Recorder
Closed captioning
You have to put in the language code by pressing setup in stop mode, select Custom, go to language select Subtitles, then enter in the code listed on page 31 of the manual on this website
http://www.emersonaudiovideo.com/pdf/om/EWD2203.pdf
Dec 25, 2007 | Emerson EWD2203 DVD Player/VCR
Closed caption on dvds
Your TV will need to have (CC) capability. To view Closed Captioning (CC) information from a DVD using the CC function of the television, turn off the Progressive Scan function of the DVD player. If the DVD player doesn't have progressive scan then follow the instructions from your TV manual to setup closed captioning.
Jul 14, 2007 | Sony DVP-NS575P DVD Player
Durabrand DVD-1002 DVD Player Logo
42 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
