Question about Polaroid FLM-2632 Television
Picture is not stable
Tv was normal and suddenly the picture started flickering.
  • 106 Answers
Check the Power Supply board to see any puffed capacitors. If found faulty cap, replace them.
Posted on Jan 05, 2008
Rca led32b30rq pictures flickers
This is the common problem with this model of RCA TV, the problem is not defective LED strips, but the power supply.
You may purchase a power supply on the net, but you can't guaranty that it is a good one.
This is the trick to make this TV work:
On the power supply, locate the R410 100K resister, solder a 220K/0.125W resistor in parallel with it, this will race up the oscillation frequency of the back light power supply circuit & make the voltage stable.
It is not a proper service procedure, but it works for us.
Jul 06, 2014 | RCA Televison & Video
Tip
How to repair projection TV (fades in and out)
This thing you have do:
  1. Open the cover of your TV.
  2. Look at the CRT driver board inside and remove all screws including the cover of that board.
  3. Then rotate the CRT board in reverse position to apply a voltage data.
  4. Power on the TV to start a voltage data.Use a multimeter (range on DC) then place your black prob(-) to the ground of the TV and the other one is place on the B+ that usually found on the 3rd pin of the ply-back transformer.Check the B+ voltage if you have a 100-120vdc.
  5. I'm sure you have the B+ voltage because your TV is not totally dead.Check the reading of the B+ if it is flickering.
  6. If the B+ voltage is flickering and you hear a clicking sound,try to hang the connection of the B+ to the fly-back then look at the reading if still flickered or stable.If the reading is stable when the B+ connection is hang.You have to replace the ply-back because it is shorted.
  7. And finally after you replace the ply-back.Power it ON.
Thank you for reading my tips.
on May 11, 2011 | Televison & Video
Its a zenith 27in the sound is good but the picture only shows a line across the screen
Make a fist with ur hand and bang on the tv bazel frame.The tv picture flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics have coldsoldering joints and requiring resoldering.If u bang on the tv bazel frame picture don't flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics are dead require changes those ics chips.If u don't have all the tools.Can't do a basic soldering work or able to changes those ics chips.Shop around for tv shops for estamate and repairing prices for repairing.
May 04, 2011 | Zenith C27A24T 27" TV
9p5511c102 the picture fades in and out ? can it be fixed ?
Good day!
Your TV is a CRT?
NOTE: If you don't have any basic knowledge about electronics and proper usage of the electronic repair kit such as multimeter,soldering iron and screw driver.Please don't attempt repair it on your own because it causes major damaged to the unit.
I hope this solution will be much helpful.Thank you and good luck.
May 04, 2011 | Philips Televison & Video
Samsung 244T 24" LCD Monitor suddenly lost
The problem you are having is a common symptom of a failure in the power supply. Parts called capacitors start failing. When they fail they stop filtering the voltages correctly and the power supply shuts down to prevent additional damage. If you would like more information on capacitor failure please check out this page on our web site explaining what they are and what they do: http://www.ccl-la.com/blog/index.php/capacitors/ If you can solder then you can do the repair yourself. We have a kit available with all the capacitors that you need to replace. The kit details can be found at: http://www.ccl-la.com/catalog/product_info.php?products_id=124 The kit contains all of the capacitors that need to be changed on the board to return it to full operation again. If you don't want to do the repair yourself we do offer a repair service for this unit. You can get details on our repair service at: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
BuddyMc
Corporate Computer
www.ccl-la.com
Nov 24, 2010 | Samsung SyncMaster 244T 24" LCD Monitor
Olevia 242T 42" LCD HDTV - Suddenly No Picture, Nothing Works
 I heard they were restructuring their company or something.
There has been a change ownership from Syntax-Brillian to Olevia International Group.
Details of Olevia brand
Unfortunately for all of us (we have 747i) service seems very poor and the failure mode you describe doesn't give me any clues despite 40+ years of service experience.
Ours is still 100% but I now suspect our trouble will come.
Nov 03, 2008 | Olevia LT42HVi 42 in. LCD Television
Flickering picture
Can you please check the model number, what is listed is not valid for a Sony. This could be a simple fix or something expensive. With the model number, I can provide you with details.
Thanks,
Dan
Apr 16, 2008 | Televison & Video
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Jan 09, 2008 | Sony KP-46S25 TV
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Polaroid FLM-2632 Television Logo
147 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
