Question about Kenmore 44273 Side by Side Refrigerator
New refrigerator Kenmore 44273 makes a noise like runing water on the frezer side for a few minutes every 3,4 days than stops and runs fine.The refrigerator is not conected to any water source.Is this normal?
  • 319 Answers
A refrigerator must get rid of condensate and "frost". There is a collection pan under the back of the unit where there is also a fan that helps removes the excess moisture back to the atmosphere.
Posted on Jan 05, 2008
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Apr 28, 2012 | LG Refrigerators
Ice maker in side by side Kenmore refrigerator model number 106.55529400 has stopped working.The ejector fingers are not stopping in correct position,from what I have read online this means ice maker...
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
.2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Hope i can help you with your problem.
Have a nice day : )
Aug 22, 2011 | Kenmore Refrigerators
Water collects on bottom of side by side freezer forming ice. Water leaks from door.
The water leak is more then likly to be a condensation problem not helped by a bad seal around the door. This would need an enginneer really.
Aug 03, 2010 | Kenmore 44273 Side by Side Refrigerator
Ice maker and water stopped working, hear a clicking sound. We tried cutting power and starting again, it stopped making the noise, but we still got no ice or water, and after a couple hours started making...
the sound from the icemaker is coming form the water solenoid valve, which needs to be replaced. if your frezer is cold then the fan is fine, most are switched to turn off when you open the door so you arent likely to see it running unless you set up a camcorder in your fridge :-)
Aug 14, 2009 | General Electric GSH25JSXSS Stainless...
Ice in bottom of frezer
make sure your doorgasket is sealing correctly. if the water runs out it shows that the defrost heater is working.
Aug 07, 2009 | Frigidaire FRU17G4JW Refrigerator
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and Freezer stopped cooling after intermittent noise
if the ice maker arm is down regardless of the water being off the valve will energize ( dry ) no this will not effect cooling
Apr 12, 2017 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Refrigerator Model #25357677791
stuck defrost timer/ thermostat. id go with both stuck because I'm looking at a diagram of your fridge now and there wired together.
i'd recommend changing both of them.
hope to be of any assistance.
Apr 26, 2008 | Refrigerators
Kenmore 44273 Side by Side Refrigerator Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
