Hello there: I hope that this is very help full please read this and try all of these ok Like i said i hope that this is very helpful Occasionally, the spray arms can get clogged with debris.
This can be caused by food or even hard water deposits. This prevents
the water and detergent from getting to the dishes to clean them. If
you notice a clog try to use a pipe cleaner, straight pin, or toothpick
to clean the holes, or just replace the spray arm.
The water-inlet valve is another possibility. This valve is
connected to the main water line from the house. If the dishwasher
can't get enough water, it can't wash the dishes. This valve is
actuated by a solenoid system. If it loses power, it can not turn
itself off. Check for sediment buildup at the valve. Sometimes when a
water-inlet valve is defective, you might hear a sound like a thump or
bang. That?s often called a water hammer. Water hammer sounds
are caused by a valve closing in the system, and yet the water in the
pipe is still flowing because of its kinetic energy. The banging
happens as the water hits the valve that prevents it from going any
further. Does this sound occur when a valve closes or when the
dishwasher is changing cycle? Sometimes high water pressure can cause
this and other sounds to occur. You can test your water pressure using
a pressure gauge. You would install this gauge to one water line in the
house, and make sure no other water is flowing anywhere else in the
home. Pressure over 60psi should be regulated by a pressure reducing
valve. If the water-inlet valve is faulty, replace it.
Popular Solutions for GE Profile PDW8400J Built-in
10 year old GE Profile built in dish washer runs but the center sprayer is not turning or moving. Is...
(More)
10 year old GE Profile built in dish washer runs but the center sprayer is not turning or moving. Is there a belt or a chain that needs to be replaced? Can I get to the motor through the front lower panel with out pulling the whole unit out? Thanks for your time!
getting error codes G5 and G4 Have GE profile built-in dishwasher no manuel - was in house when we...
(More)
getting error codes G5 and G4 Have GE profile built-in dishwasher no manuel - was in house when we bought it
