Question about Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car Video Player
I got a ?
I need to bypass the emergency brake on a Dodge Dakota for a dvd player?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Run the emergency brake wire to your ground and your goog to go
Posted on Feb 28, 2008
    Brigadier General:
  • 6,966 Answers
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Posted on Jan 05, 2008
ABS and brake lights are on
Either your emergency brake is stuck or you need to bleed brakes. To check the emergency brake pull on it as you pull release.
Apr 29, 2013 | Thule 2003 Dodge Dakota - Club cab -...
BYPASS THE KENWOOD DDX8017
Im guessing since this is an in dash dvd player your trying to bypass the emergency brake so it will work with the vehicle in drive. If this is the case all you have to do is take the wire that goes to the emergency brake and ground it somewhere.
Mar 04, 2013 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
How do u disconnect the emergency brake on a 1987 dodge dakota 4x4
It depends on where the cable is stuck.
You can disconnect it at the connection points, you have a front, center, and two rear cables. But if the cable is stuck at one of the brake drums, disconnecting it at the front or center connector won't free up the brake shoes.
Jan 24, 2013 | 1987 Dodge Dakota
How do I bypass emergency brake so the dvd player in my car works
This is against the law and you will be fined if stopped by the police
May 19, 2010 | Car Audio & Video
How do i bypass emergency brake wire on my clarion to play movies
connect the wire to a ground/negative point, please note this is a saftey feature.
Nov 15, 2009 | Clarion Car Audio & Video
Bypassing E-Break
Just connect the emergency brake wire to earth (vehicle body)
Jun 17, 2009 | Jensen VM9410 Car DVD Player
Bypass brake
What kind of vehicle? If you can find where the wire to the emergency brake switch (usually there is a switch at the top of the emer/brake pedal) was tapped into. Take a a test light (Bought at auto supply store) and find out if your switch is grounded or has 12vdc when emerg/brake is depressed. If it is grounded then find the wire from th dvd player and attach it to a frame ground. If it is 12vdc find some other source of 12vdc in the fuse box and put the wire to that source. If I knew what type of vehicle I can possible walk you through it.
Feb 02, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car Video Player Logo
352 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
