if its frozen to the point that it will not turn off, lift the external antenna and push the reset button, then start it up again and see if its ok. if not
make sure its has a good charge,plug it in to the
usb port
on your
computer for a few hours.
if that fails, try a reset
note: the master reset will erase all your saved
datawith
the unit off,and unplugged, try pressing and holding your finger on the low right
corner of the screen and slide the power switch to the on position
until you see the message "confirm if you really want to delete
all user data?" hit yes and let it restart. then it will set up the
nuvi again, so follow the prompts.
hook up the nuvi to the web updater and get the latest update
you can get the Web Updater
HEREbill
