Question about E-Machines eMachines Desktop PC
Problem with my computer
My computer when turned on only displays computer on connected to the monitor, when everything is connected. thank you
    Novelist:
  • 101 Answers
Hi Marie!
Can you be more speific on the problem. I am afraid I don't under stand.
Posted on Jan 05, 2008
Lenovo g470 vga display issue
fn + f3 change display
fn + f5 wifi on/off
May 03, 2017 | Lenovo G470 Core I5-2410m 2.9ghz 4gb 500gb...
When i switch on the monitor the on/off button blinks and i don't get a picture. johanalvemalm@people.net.au
Most monitors will behave that way if they don't get a signal from the computer so there's nothing to display. A quick check of the monitor itself is to disconnect the signal cable from the computer and then turn the monitor on. Most monitors will display some kind of a message that there's no input and to check your cable connection. Then the power indicator changes color as the monitor blanks out.
You will probably find that your computer isn't starting up when you turn on the power. A common computer problem is that it will turn on when you press the power button, showing a power light and you'll hear the fans inside start running, but it never actually starts running. Then there's no video to the monitor and you see the trouble you described.
The monitor may still be bad. If everything seems to be starting normally and you hear the Windows startup sound through your speakers, but the display stays blank, try another monitor. If that one works, you'll need to have the bad one serviced or replace it. If the test monitor is also blank, the video circuitry in your computer has failed. If the video is built into the motherboard, you can install a plug-in video card as a replacement.
If the computer is turning on but never starts running, that can be a pain to figure out because several things can cause the trouble. The most frequent causes are a bad power supply or motherboard. Bad RAM or a defective drive or other device connected to the motherboard can also keep the board from starting up. The processor itself can fail, but that's not common. I start by removing everything except for the power supply, processor and fan to see if the motherboard is starting. If the motherboard doesn't give a "no memory" error (usually a long beep), you need a power supply or motherboard. Otherwise, the basic hardware is fine, and you can start replacing parts until the trouble comes back, and then you'll know what caused it.
Good luck, and thanks for using Fixya!
Dec 28, 2010 | Samsung Syncmaster 940BW LCD Monitor
My monitor has a message "input signal out of range" I tryed to open the menu but it will not open
Turn Off the computer and turn off the Monitor. Now turn on the Monitor, unplug it from the Display port of the computer and press the menu button several times. Now reconnect the Cable to the to the Video port. Turn on the Machine and check if it boots up normally or not.
Also try connecting it on another computer, the problem may not be the monitor, but the display settings of the computer. You'll need to change the settings of the computer after connecting another monitor or vise versa.
I don't mean you monitor is having no problem, of course it could be but you'll be able to find out after you connect to another computer.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Computers & Internet
No display everything turns on windows loads but no display
We can further isolate the issue by connecting an external monitor to the notebook. If the display is fine with the external monitor, this clearly indicates that the issue is related to the LCD screen. Otherwise, it is due to the some other internal hardware.
You may follow these steps to connect the notebook to an external monitor.
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
External monitor.
May 14, 2010 | HP Pavilion DV9620US Notebook
No pic on monitor. connected everything to computer and no picture on the monitor
Please double check, you should have two cables out of the monitor and connected.
1. The power cable to your UPS/ AC switch. 2. display cable connected to the CPU(main box).
Based on the information you gave one or both of these cables are not connected/switched on.
Thanks.
Feb 03, 2010 | E-Machines eMonster 550 PC Desktop
Cpu does not connected to monitor
I am guessing that you see lights on your computer, but no display on your monitor.
Have you tried another monitor? If you have and still no display, try unplugging everything from outside the computer except the monitor and then try again.
If no display, unplug power from computer and open the computer. Remove all expansion cards other than the video card. Disconnect all the cables from all of the drives, then connect power and try again.
Let me know if you need more help.
Honest1abe
Feb 25, 2009 | ASUS P5V800-MX Motherboard
Hannspree HF229H
I think that you have multiple displays enabled through your video card. Just disable multiple displays.
Aug 16, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
E-Machines eMachines Desktop PC Logo
26 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
