I downloded service pack 2 and try to istall it on window xp pro ,but in half way of of setting up it will stop and said setup dined I check the serial and
is xxxxx-OEM-xxxxx-xxxxx? cna you help me?
Please make sure you have disabled, or unistalled any antispyware, especially Norton. Disable any antispyware. If you don't have have any antspyware, download Superantispyware here. http://www.superantispyware.com/ Install it, update it, run it, and uninstal it. Go to start>run and type in MSCONFIG. Click on the startup tab, and check the Disable all box. Click done, and reboot. Now try and install SP2.
If you still can't install, check out this link. It requires editing the registry, to be careful. http://support.moonpoint.com/os/windows/xp/xpsp2-install-problems/
It generally indicates the serial number used for the installation of the original software on your computer has already been activated on another machine.
This is typical of copied software.
As this is an OEM version, Microsoft only allows the software to be installed on a single computer.
Attempts to perform any updates are denied.
If you are the owner of the original XP installation software and have the COA (certificate of authenticity) you can contact Microsoft to allow updates, possibly with the issue of a new key.
Hola muy buenas... No me quiero enrrollar asique lo escribire corto... Tengo intaldo en un disco...
(More)
Hola muy buenas... No me quiero enrrollar asique lo escribire corto... Tengo intaldo en un disco duro el SP1 y en el otro el SP3 Que hago para quitar uno de los dos...(Preferiblemente el SP3 lo quiero quitar...porque solo uso el SP1) Gracias de antemano.........
