Question about Mitsubishi VS-60111 60" Rear Projection Television
Toshiba TZ55X71 Hi, our projection tv is always shutting off. we don't use it for a couple of days and it is fine and then the same thing is happening. Any advice other than buy a new tv?
    Problem Solver:
  • 18 Answers
Check if fan is running.
Posted on Jan 05, 2008
6ya staff
SOURCE:
Toshiba model TZ55X71 pojection TV
If it's still under warranty you could bring it black to the place you purchased it and have them fix it for free. Trying to fix it on your own could not only make it even worse, but endanger you in the process.
Jul 29, 2008 | Toshiba 50H82 50" Rear Projection...
My tv keeps shutting off. it works fine for a couple of days and at times it only goes back on when i keep plugging it into the power outlet.
Toshiba 55H70 55" Take the back off and pull the HV power board and check all the solder joints, seem to me that you has a cold solder joint. check it out be carefull with high voltages.
Jan 27, 2011 | Toshiba 55H70 55" Rear Projection...
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Toshiba tz55x71 won't turn on
http://fileshare.eshop.bg/index.php?what=search2
If you are a little handy, there is alot of information here.
If not, I will dig for info.
Mar 04, 2008 | Televison & Video
TOSHIBA TZ55X71
Sounds like something minor in the standby voltage circuitry, However it will eventually prevent the set from working. I would check the voltage regulators and capacitors in the power supply.
Feb 24, 2008 | Televison & Video
TZ55X71 screen and protector broken part #'s??? How to clean lenses???
http://free.atozmanuals.com/index.jhtml?partner=^CG7^xdm524&s1=adwords-22e539d9e6369d28d62ae4a9a56a40ce&s2=5498ad8d4dd2413b934ce0ce75dd43fa5a5a4bdd&s3=&s4=&s5=&utm_source=adwords&utm_campaign=808986899&utm_term=segment+ski+8933745652033491368&mt=&network=d&kid=kwd-10009911&aid=41398201826&lpurl=http%3A%2F%2Ffree.atozmanuals.com%2Findex.jhtml%3Fpartner%3D%5ECG7%5Exdm524&gclid=EAIaIQobChMIiqrvqcXV2AIVi4TtCh3XngsqEAEYASAAEgJh1vD_BwE
Jan 13, 2018 | Televison & Video
Toshiba TZ55X71
It really depends. If the board is cracked or broken then I would say no, if it is something more simply repairable then sure, call a repair shop to get an estimate then go from there. With the price of TV's these days it may not be cheaper to replace, but then again your current one may not even be repairable.
Jan 27, 2008 | RCA P46810LV 46" Rear Projection...
55 inch projection tv
BUSTY35,
Here is your screen info = protector...PS5501....$155.00
Lenticular = 23430819....NLA Fresnel..23430635...$135.00
...........................................T.
Dec 17, 2007 | Televison & Video
Toshiba TN61X81 HD Cinema Series Sound Problem
what type of connection did you use for your playstation 3 to your tv....
Aug 10, 2007 | Toshiba TN61X81 61" Rear Projection...
Mitsubishi VS-60111 60" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
