Question about Onkyo Audio Players & Recorders
Onkyo 1020F direct drive turmtable will not maintain proper speed
My vintage Onkyo 1020F turntable has trouble in maintaining the correct LP speed. During various times it slows down no matter what LP I am playing. I have tried adjusting the play speed dials but it never brings it up to the speed in which the strobe markings appear to be standing still.
    Top Expert:
  • Onkyo Master
  • 40,527 Answers
Probably the motor is defective.
Posted on Feb 13, 2018
  • 155 Answers
SOURCE: DVD system shuts down during DVD play with various parts of shows
I think this is the answer you are looking for.
Let me know if you need more help.
Knowledge Article C337191 Error: The message PROTECT or UNPLUG shows in the display.
Follow this procedure to troubleshoot when a PROTECT or UNPLUG error is displayed.
IMPORTANT: The top of the receiver must have proper ventilation to keep from over heating.
  1. Reduce the volume level.
  2. NOTE: If the receiver is played at the maximum volume level it may enter the PROTECT mode. Maximum volume listening will cause the receiver to run hot and drain the output capacitors.
  3. If both the A and B speakers are being powered by the receiver at the same time, turn off the surround sound option.
  4. If protect occurs only when using a DVD player, the sampling frequency may be set too high.
  5. NOTE: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the user manual for specific information.
  6. Ensure the speaker wiring is not damaged and is properley connected to the back of the receiver and speakers.
  7. If the issue is still unresolved after completing all of the troubleshooting steps, service may be required.
Created: Thu Sep 16 14:49 2004 | Last Modified: Wed Jan 11 09:02 2006
Posted on Feb 13, 2008
  • 1512 Answers
SOURCE: My turntable is playing a tad makes every record sound warped!
Hi CGS8021
Sounds like the belt is failing. You can get one from here
Where in the world are you? I will link you to the closest source.:)
Posted on Apr 30, 2008
  • 4 Answers
SOURCE: dvd always says no disc
I used a lens cleaner - after about four goes with it the player recognised all my discs again. You should definitely try that if you haven't already.
Posted on Nov 27, 2008
  • 2007 Answers
SOURCE: engine starts,reaches high rpm,then slowly returns
Vacuum leaks. Check all hoses and intake bolts. Leaking EGR or plugged PCV valve. Air filter plugged. Leaking head gasket. Worn timing chain. Camshaft lobes worn. Valves burned or leaking. Fuel idle control system or sensor. Good luck!
Posted on Jul 03, 2009
  • 8546 Answers
SOURCE: I have a problem adjusting bass and treble. I
Figure out why the TV has so much bass. Look into its audio controls. I'd also consider attaching and listening to the TV-related audio directly and digitally through the Bose from the source(s) rather than through the TV and its questionable electronics.
Posted on Jul 22, 2010
How do I revive the turntable of this vintage record player? It turns, but slowly. Thank you.
It needs lubrication. If it is a "rim drive" style turntable (as opposed to belt drive or direct drive), you may need to replace the rubber roller. If it is belt-driven, you may need to replace the belt.
May 20, 2015 | Vintage Audio Players & Recorders
The turntable runs great for half the way throw the lp and then it speeds up to a 45 speed
Any infinitesimal change in belt temperature would not cause such a change in speed. The speed of your turntable is governed by an electronic circuit and this is where the trouble is.
The cost of a repair is going to be mostly labor which may exceed the value of the value of the turntable.
Mar 10, 2015 | Sony PS-LX250H Turntable
Once the needle touches 33 lp it speeds buy the songs
Yes the platter speeds up until the moment comes. 0'5 sec later and then the electronics take over , want you to try quartz activated and after that quartz put out and then you have a pll. try moving the pitch a bit, cause the 1210mk2 aint tables which you want for the good maintainence. if it helps or doesn't , mail as fast as you can
Mar 18, 2014 | Technics Audio Players & Recorders
How can we achieve fuel efficiency while driving my car?
Do these these things
-Inflate your tyres to correct pressure or a little over, when cold
-Don't accelerate quickly or rev the engine up , most especially when cold
-Try to drive smoothly in traffic with a light foot, not jerkily
-In cars with small engines A/C will consume more fuel
-Fill up with the least ethanol that is legal, and that your car will tolerate. Consult your driver handbook. Efuel gives less economy
-Don't cart heavy loads around in the car for convenience' sake. Take them out till you need them.
-Don't put roof racks and travel pods on when not needed. These create drag
-On the highway travel at 10% under the limit. Less and you will irritate others, but high speeds increase fuel consumption greatly
Oct 30, 2013 | Cars & Trucks
I have a technics slbd20d for about 6 yrs. teh speed started to fluctuate, so i replaced the belt, with an orginal replacement from panasonic, and one from lp gear to match my turntable. but the speed is...
u mean the recor speeds and slows down? if its an older turntable there is some play in the bpms thats why most people get direct drive. my sugguestion is to look it over and tinker w things but dont break it. im sure you can find a manual online
May 05, 2011 | Technics SL-BD20D Turntable
MY Technics 1200 Rotates Out Of Control. What needs To Be Done To Fix?
It sounds like you need to replace the belt. If it's too loose, it will not maintain the proper speed.
Nov 04, 2009 | Technics SL-1200 Turntable
Connect Onkyo CP-1020F Turntable to Theater System?
Yes. It needs to have Line Level (slightly amplified or pre-amp'd) before your home theatre system can 'hear' it.
Oct 06, 2009 | Audio Players & Recorders
Turntable speed erratic
It is likely that grease has hardened and as the gears rotate that grease is interfering with normal operation. Take the unit apart and have a look at the drive mechanism, if there is something in the gears you should be able to see it.
Jan 01, 2009 | Denon DP-47F Turntable
Magnavox Console Stereo turntable does not turn at correct speed
I'm in Nashville, where can I have my 70"s Magnavox stereo console serviced to get bugs out of it as well as get new cartridges?
Nov 24, 2008 | Teac AG-V1050 Receiver
Sony PS-LX250H turntable won't turn
check the switch that make the lp running located it on the arm (arm uses to put it on the LP) check the motor Make sure no debris whatsoever that can disrupt the LP to turn
Aug 06, 2007 | Sony PS-LX250H Turntable
100 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
