Question about Samsung HCN529W 52" Rear Projection Television
QUestion. My question is my samsung hcn529w lost its focus. the color coding is all off. I tried to adjust it but everytime I turn it off, it goes back to double screen. I tried the perfect focus but it is no help. what can I do
  • 3 Answers
Replace Convergence Ic's or convergence amp panel
Posted on Jan 05, 2008
Tv has a pink smudge across the top of the screen and colors at tp of screen do't seem to align pink and blue and green. Tv was banged when carrying up 2 flights of stairs.
Your convergence has failed and need to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
Apr 24, 2011 | Samsung HCN529W 52" Rear Projection...
I have a HCN529W 52 in. Samsung and the picture looks like it is 3D, what are the symptoms when the convergence board goes out?
aztoonnout,
The symptoms are exactly what you have described. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, where to get parts at the best price and how to finish the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 02, 2010 | Samsung HCN529W 52" Rear Projection...
My samsung hcn529w rear projection tv has convergence problems. how can i manually adjust the color guns
you are reaaly looking for a nightmare messing with the convergence rings to adjust the convergence you need to change the two ics and probly some reistors
May 18, 2010 | Samsung HCN529W 52" Rear Projection...
The color is split. Yoy see distinct color shadows Auto focus did not help urning the t off for 30 mintues and back on did not help
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Samsung HCN529W 52" Rear Projection...
Samsung tv hcn529w
this does require soldering the ic's you have to change there are two of them plus sometimes you have a bad resistor or two and some bad pico fuses if you can solder and have a meter you could do it
Jan 25, 2010 | Samsung HCN529W 52" Rear Projection...
Samsung rear projection TV audio no video
There is a problem on the deflection board (BP94-00501B). I have tried replacing the flyback, both convergence IC's and the horizontal output transistor without any luck. I finally bought the whole board from encompass parts for ~$120. Hope this helps.
Sep 23, 2009 | Samsung HCN529W 52" Rear Projection...
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Picture is squished in on all 4 side of TV and colors are all dis
You will not find the problem in deflection board it will go back to convergence board,I repaired one that would not Magic focus cause was on connectors from power board to convergence board the one closes to up front of board one of the pinns was bent under so when i pluged it back in did not know after lifting up connector under tiny pins 1 of them was bend under straighten it so it could plug in right Fixed problem.
Dec 17, 2008 | Samsung HCN529W 52" Rear Projection...
Samsung HCN529W 52" Rear Projection Television Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
