Question about Universal Remote Control Activity Based Universal Learning Remote Control
I have the toshiba RD KX 50 DVD REcorder
I have a Samsung TV HL-R4266W . I wish to program the toshiab dvd recorder remote to change channels on the Samsung TV.
What codes do I use?
SOURCE: program code
onkyo rc 518m find
Posted on Jan 06, 2008
  • 2712 Answers
SOURCE: program my remote
You can find the remote control codes for different brands of devices from
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Posted on May 23, 2008
  • 8 Answers
SOURCE: Program codes for tv and satelite.
The manual
Posted on May 25, 2008
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: my tevion universal 8 in 1 remote won't work any tevion devices
tevion is made by konka, try using konka tv settings.
Posted on Feb 21, 2009
  • 10865 Answers
SOURCE: I need codes for Quarsar TV and Classic DVD
Posted on Apr 26, 2009
0 characters
1 Points
Need a code please for tecknica tv 25-56D
1. Yes, a universal remote will work just fine. Buy a universal remote and then one by one, try the following codes until you find the correct one: 000,001,004,005,008,009,013,042,051,053,058,105,109,170,174.
2. Maxell is a recording disk and often times cannot be played on certain DVD players.
Mar 12, 2014 | One For All URC 7740 Remote Control
I need to program my samsung AH59-01617R remote to my samsung tv
I am asumeing that the remote is from your dvd recorder/player which you wish to use to control your tv?
Which is possible. please follow the link to Samsung support, there are step by step instructions on how to use your dvd remote to control your tv.
Feb 24, 2011 | Samsung AH5901169L Remote Control
Need remote control code for Univeral Remote.
For clarification pf the problem, may I know what exactly the brand and model of the remote you are intended to use on your recorder and tv.
Update me again here
Jun 04, 2009 | Remote Controls
Prog Code on RCA311ST for Toshiba DVD Recorder
yes there is a video on you tube how to program a universal remote
Jan 17, 2009 | RCA RCR311S Remote Control
Need help on using a sony RMT-833 remote control unit
The Sony RMT-833 remote is for a Sony Camcorder - see
I think you mean the RM 833 remote - if so try eBay as listings there suggest it works with Number: RM-833 Compatible with TV Models: KVX250, KVX2501D
Hope this helps
Sep 25, 2008 | Sony RMT-833 Remote Control
Universal Remote code for VCR/DVD recorder.
Use the remote's "Code search" feature. It'll run through every code in it's database and when you see the player turn off, you store the code. If non of the codes work, then it's not compatible.
Hope that fixed ya...
Apr 02, 2008 | Remote Controls
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Need to program my tv and dvd recorder
Magnavox DVD
Sanyo 017,021,039,056,057,058
Dec 20, 2007 | One For All URC4220 Remote Control
Programming my rca universal remote for basic cable the stations wont turn
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
Dec 09, 2007 | RCA Universal Remote Control
Remote Controls Logo
Top Universal Remote Control Remote Controls Experts
Are you an Universal Remote Control Remote Control Expert? Answer questions, earn points and help others
