Kenmore 98702 Stacked Washer / Dryer
Problem for Kenmore 98702 Stacked Washer / Dryer
The long peice that goes out the window
By melissa_h275 on Nov 06, 2009
the long peice that goes out the window
Solution #1
posted on Nov 06, 2009
Not Rated)
hmlee390
Rank: Guru
Rating: 91%, 152 votes
the long tube that carries the warm moist air to the outside thru the window .. has to be kept clean inside ... if it gets clogged with lint then the dryer will no longer work correctly ... the tube should be removed and cleaned each year or so ... you can also just replace it ... they have several types at most hardware stores .. on the outside of the window should be a flapper valve .. that opens only when the dryer is running .. otherwise it closes to prevent weather leaks and animals from getting in .. that should be cleaned or replaced also once in a while .. the hose is eather 3 inch or 4 inch diameter .. you can snug it up with a hose clamp designed for your size .. that will prevent it from coming loose .. smooth inside pipe is best but the metalic extendable hose is acceptable .. the plastic hose is less desirable .. the smoother the inside the longer it will last before becoming clogged ..
Was this helpful?
Yes
No
Popular Solutions for Kenmore 98702 Stacked Washer /
Questions and Unsolved Problems for Kenmore 98702 Stacked Washer /
Do you recommend Kenmore 98702 Stacked Washer / Dryer?
Answer
Answer
the timer on my kenmore washing machine doesn't automatically move to the next cycle
Answer
how do you open the top of washer to inspect tub of a kenmore washer/dryer
Answer
leaking from the bottom. Also agitator needs help to start. how easy is the pump to access?
Answer
I took the screws out of the inside back of dryer it shorted out and now I can't get the screws back... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
