Question about Sennheiser MD421-II Professional Microphone
Dead md421 Bought it for $10 and it's dead. How do I take this thing apart to get inside? Is there any way to get an exploded view of one? Thanks
Ignore GazllFixIt...
If it's dead, a connection is already broken inside.
Much more unlikely is that the capsule is at fault - and if it is you can't make things any worse anyway.
Who cares if you break a connection when you take it apart - as long as you can use a soldering iron, it's easy enough to fix. If you can't, why would you be taking apart in the first place ;)
You'd be mad to send it to Sennheiser to solder 1 or 2 points then send it back to you! Waste of time and money.
Try learning something yourself, especially if it only cost $10 and doesn't work to begin with.
Remove the capsule assembly - desolder and disconnect the wires at the base of the mic (not from the capsule) yourself (see, opposite of last advice), then connect them directly to a cable with an XLR on the other end. Forget about ground for now.
Now plug it in...do you hear anything? If not, get a multimeter and check continuity between capsule and your XLR. If you have continuity, throw the mic out. If not, replace those wires. Still nothing - chuck it out.
If you are hearing something (it should sound absolutely fine, clear, loud etc), ...find the broken connection elsewhere...but also, be happy because it definately still works and is definately fixable and you can do it yourself.
Posted on Jul 24, 2008
  • ultanium Mar 20, 2011
    To get the MD421 open, slide the serial number plate out of the way, remove the screw that holds the XLR jack in. Remove the XLR jack, and then use a 7mm driver to remove the core of the mic. Good luck, you got a great deal for $10!
    Scholar:
  • 103 Answers
A microphone such as the MD421 does sound too good to be true for $10!
I would strongly suggest you do not try to take it apart as the connections inside will be destroyed. I know people that have had a go at taking it apart & destroyed their mics, ended up sending them back to Senheiser & having to pay more to get the extra damage fixed. It really is a false economy.
There's some info here:
http://www.coutant.org/md421u4/index.html
...scroll down for techical data sheet & manual.
Posted on Jan 08, 2008
Need to take it apart to replace the grill
First you must loosin the connector.
There's a little shield with the serialnumber you can slide away.
Underneath that you will find the screw to loosin the connector/filter.
If you look inside you will find a bolt, unscrew that one and the element and grill will seperated from the housing.
Thats what I remember after 25 years.
Good luck,
Gerard
Apr 23, 2011 | Sennheiser MD421-II Professional...
Where is the oil pump located on a 1998 Chevy S-10?
Please don't forget to rate! Thanks!
Exploded view of a common oil pump mounting-4.3L engine shown, it is the bottom of your engine, located under your oil pan.
Exploded view of a common oil pump mounting-2.2L engine shown, located under your oil pan.
Apr 19, 2011 | Chevrolet S 10 Cars & Trucks
How does one take a Sennheiser MD 421 apart?
At the connctorside there's a small metal plate with a serial number.
You have to bench it a little, underneath there's a screw.
Unscrew it and you can take the connector out.
What I remember after 25 years is that there is a screw inside which is loosing the grill and element.
I've written it before with succes.
http://www.fixya.com/support/t3134138-apart_sennheiser_421
Regards,
Gerard
May 17, 2010 | Sennheiser MD421-II Professional...
My saw is really stiff when you try to change the angle .I oiled it but this didn't help. I would like to know how to take it apart but I am un sure how to do it and what is in the boxed off area...
Exploded diagram with parts list for LS1016 10" Dual Slide Compound miter saw is here.
Owner's manual is here. If these aren't quite what you need, you can view other models of Makita miter saws, here.
One thing to bear in mind. There's a miter angle lock and a slide lock on the bottom front of the saw. If you don't have the miter angle lock loose enough, it will be difficult to turn the saw.
If this answer was useful, please vote for it. Thanks!
Apr 14, 2010 | Makita 10" Dual Bevel Sliding Compound...
Exploded view of Berings and washer HELP ME!!! GE WSM2700W
Go to appliancepartpros.com and type in your complete model number. There are some excellent exploded view diagrams of your entire unit, complete with part numbers. Another source you can try is searspartsdirect.com. I hope this helps you.
May 29, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Repairing the psp
if i was you i would take into a professional shop because you have to remove all the umd drive and motherboard to get to the lcd screen
Mar 23, 2008 | Sony PlayStation Portable (PSP) Console
Grease on the inside of lens
stripping these lenses can be tricky, i suggest you get in done by a panasonic technician. you dont want to damage anything making it worse and cost more in the long run.
Feb 17, 2008 | Panasonic PV-GS35 Mini DV Digital...
Md421-II
first use hair dryer for a minute if you have.
second- bring any box with suitble size to mic and put a rice on it and put the mic on it for a couple of days{rice absorb wet and humidity}
Dec 05, 2007 | Sennheiser MD421-II Professional...
Sennheiser MD421-II Professional Microphone Logo
721 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
