Question about RCA TH1101 MP3 Player
Inverted Display, faded, and screen goes blank
Tried new batts., and it works for short time. Batt still good. How can I set the screen back to normal? Looks like you would need a mirror to see the words correctly.
  • tankerjj Jan 05, 2008
    Has not been outside. Usually sits on night table beside the bed. It was just turned on and started doing it. My wife likes to listen to it before she goes to sleep. Is there a way to fix it or should I buy her a new one? Thanks in advance.
    Problem Solver:
  • 7 Answers
If you let it get to much direct sunlight might make it do something similar to that
Posted on Jan 05, 2008
  • utah carroll Jan 05, 2008
    I AM NOT SURE BUT IF YOU HAVE A WARRANTY ON IT YOU MIGHT COULD GET ANOTHER ONE. BUY IF NOT YOU MIGHT BE BETTER OFF BUYING A NEW ONE BECAUSE IT MIGHT BE CHEAPER THAN GOING THROUGH THE TROUBLE OF FINDING SOMEONE TO WORK ON IT. BECAUSE YOU WOULD PROBABLY HAVE TO PAY FOR HIS/HER WORK AND THE PART OR PARTS THEY HAD TO INSTALL.PLUS YOU MIGHT HAVE TO PAY FOR ORDERING THE PARTS IF NEEDED. IF I WERE YOU I WOULD SEE FOR MYSELF WHICH MIGHT BE CHEAPER.
Test stator
The stator is just a coil set for the generation of DC from an armature that spins. You need to regulator to change the voltage etc. That is what has failed. Find the one on this page that looks like yours. Let See What We Have Here
Dec 26, 2017 | Garden
My forerunner 50 is randomly resetting itself. Sometimes it shows Lo Batt but then doesn't sometimes the screen goes blank but pressing any buttton a few times brings the display back at which point I have...
Remove the battery, clean the contacts with alcohol, and replace with fresh cr2032 battery. Instructions are here: http://gnjmch.com/public/tips/GarminF50.Battery.html
Mar 05, 2011 | Sport & Outdoor - Others
My 6600 nokia phone automatically turned off when it is on display or standby mode. I just tried to format it but it still turned off.
Hi,yr mean turn off is the phone shut off ? Or the screen blank off slowly ? If shut off ? Mayb the batt or batt connecter pro. The screen blank off slowly,even do format still same,Mayb phone's flash Ic pro, U need Sent for repair. Pls rate me if my solution useful,thx..
Feb 13, 2011 | Cell Phones
Palm pilot will not stay powered up. It has power for about 3 seconds then goes blank. There is a full charge on the battery too.
Sounds like it is time for a new battery. Not expensive.
Google for palm 515 battery and you should find a few places. Worth doing if you can do yourself or if you really like your 515 ;-] Labor cost on top of the battery might be the deciding factor.
Mar 10, 2010 | Palm m515 Handheld
At Dell screen the d600 shuts off
GO INTO THE BIOS AND RESET TO DEFAULT SET UP SETTING.RICHARDM69
Dec 15, 2008 | Dell Latitude D600 Notebook
Display screen is blank
Panosonic KXTG5632 Screen is blank lights up but no numbers or info.phne works fine. Tried removing batt. Any sugestions
Thanks Bill
Jul 15, 2008 | Panasonic KX-TG5632 Phone
1997 Jeep grand Cheeroke
My Answer:
Being an expert in this Electronics field this should be fairly easy.
It appears your charging system is functioning OK as you did the QUICKIE alternator/regulator test and that part appears to be fine.
Next - Never ASSUME you have a good, or NEW battery. I've seen brand new batts fail a few months after purchase for no known reason at all. Water level should be topped off esp during Hotter weather as water level will drop as the batt ages.
AND - when in doubt - Always do a hydrometer test on each cell, and make sure all cells read equally at approx 1.285 to 1.290 - indicating a fully charged batt.
When doing a LOAD TEST with an external 100 Amp Load Tester make sure you disconnect the POS terminal cable (or better yet both batt cables) on the batt before doing a good Load Test on a fully charged batt.
Batt voltage on a good fully charged batt should never drop much below 11.4 to 11.7 volts doing a 10 second load test using a Load Tester similar to say one bought at Harbor Freight Tools for like $15 when they are on sale.
If the top of the batt is wet (for whatever reason such as dew-point or leaky batt acid) this will cause the batt to self-discharge right across the top of the batt. Just like putting a small light-bulb across the batt posts and causing a drain. It happens more times than you care to know. When I worked at SEARS I seen it day in and day out......trust me I know!
Next - you'll want to check for a couple things at night, or else daylight will work as well - if you have good eyesight. You want to check and make sure your "backup lights" aren't ON when the Headlights Switch is turned OFF and the Ignition Switch is OFF as well. Sometimes a SHORTED Transmission Backup Light Switch will cause a battery drain with everything shut off. Sometimes!
Also - If you have any Interior Lights left on when the SUV doors are all closed that will surely drain the battery down.
A radio/stereo left ON will do the same as well.
A shorted tail-light (or any marker light) will also cause a battery to drain over time.
Jeeps that have a under the hood light Mercury Tilt Switch for the Engine compartment sometimes can have this switch mounting come loose and when you shut the hood the light will actually stay lit thus draining the batt down as well. Make sure you check it at NIGHT during darkness as it will show up better.
If all this proves NOT to be the cause then you will have to do an actual DVM inline amp meter test to see just how much current leakage (shorting) you have. A fuse block isolation test will next have to be done to isolate from which circuit leg the short (or current drain) is coming from.
Once that circuit is isolated then it's just a matter of finding the shorted device or shorted wire(s).
If you just added anything new electrical wise to the Jeep recently- then that is a good starting point - for if the problem wasn't there before that time, and now it is - then there is your culprit!
If you are using an external battery charging PV (Photo-voltaic) panel, and it's bad for any reason - then it will drain your battery down as well, esp if the blocking or back diode goes bad.
Also - If you have a dual battery system with a BATTERY ISOLATOR installed you might want to double check all your wiring there as well - as I've seen them go bad and cause many a battery problem!
It's gotta be something I just went over here - as I covered everything......
Let me know what it was OK?
Thx,
Frank
Jul 12, 2008 | 2003 Jeep Grand Cherokee
No power
why didnt you hook it up to your wiring harness and were is the red wire hooked up the yellow is the memory wire make sure you have a good ground
Feb 09, 2008 | JVC Sirius KD-G300 CD Player
RCA TH1101 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
