Question about Alpine CDA-9847 CD Player
Alpine amp i have a 850 watt alpine mono amp, everything turns on there is power to everything but my problem is there is no sound, when i was hooking it up to my box it did spark, did it go into a safe mode and if it did how do i reset it
  • 21 Answers
You could have damaged the speaker, try another speaker or buy a volt meter and check the speaker ohms. You could also set the meter to read A/C voltage and put each lead to the positive and negative speaker output on the amp and see if the amp is outputing any voltage. Hopefully it is just the speaker and not the amp.
Posted on May 21, 2009
6ya staff
SOURCE:
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
I have one alpine type R 12 SWR-12D4 1000 watts rms-3000 watts peak, and I have it hooked up to the Alpine MRP-M500 mono power amp (500w RMS+1 at 2 ohms and 300w RMS+2 at 4 ohms) I have all great...
I usually run an extra pair of RCA's when I do an install. This way if you have a problem with one you're already set or if you upgrade you won't have to tare you car apart again.
Apr 03, 2013 | Alpine MRP-M350 Car Audio Amplifier
Can a Alpine X-power mrx-m100 mono powered amp push 2 15" jbl subwoofers model gto1514d???
I have installed car audio equipment for over 40 years on end off. End can see you don,t have the slightest clue what in the hell your doing, Speaker wire doe,s not have to do with it cuting out, It is because of the way you hooked your subs up, That no one can explain to guys like you in writeing,How to do it properly, Number 1, That amp is 2( OHM) Stable, You should be useing 2 (OHM) subs on it,Not 4 (OHM) subs, Take it to some one that no what in the (Hell) There doing (Before) you fry your amp.
Oct 20, 2012 | Alpine X-Power MRX-M100 Amplifier
I have everything hooked up and i keep blowing the fuses in the amp?
did you use connectors on the amp or did you just strip the wire back then screwed the wire down? is the amp brand new?
Sep 12, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
My alpine v12 turns on but no sound
no you don't have to hook up both of the power terminals. but should have it hooked up so you get the proper power to the amp. use a disubution block with two 8 gauge wires.
do you know if the radio's rca jack's are good? have you ever had another amp in the car? if it worked before try new rca's from the radio to amp. recheck all connections from amp to speakers and make sure no wires fell off.
Sep 22, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Amp makes noise. I am purchaseing a new amp
Hello termite440,
A mono amp will generally provide more power for subs. And for those Audiobahn's, you'll want something that will provide a minimum of 500-600 watts RMS to each, a least a 1000 watt amp. At the low end, something like the Alpine MRP-M1000 or the Orion HCCA-D2400 will provide 1000-1200 watts. I'd recommend the Alpine. For more power, and another $100, look at the Alpine M2000, or for another $250, the Rockford-Fosgate T1500-1bd.
Hope this helps.
Apr 28, 2009 | JVC KS-AX5500 Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
How to unlock my alpine mono power amplifier mrd m500?
Hi. If you shorted (touched) the speaker wires together, or let them touch the chassis of the car, then it may have locked out. Just turning the amp off and back on will fix this, so it sounds like you have done damage to it. Most amps have a speaker relay which gives a click sound when you turn on. If there is no click, then it may have a power supply failure.
Mark
Oct 24, 2008 | Alpine MRD-M501 Car Audio Amplifier
Alpine CDA-9847 CD Player Logo
137 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
