Check if the motor is running, then proceed as follows:
If
the motor is running, the washer has a frozen pump pulley or
a broken pump belt. Remove the pump from the
washer and try to rotate the pulley manually. If it does not turn
freely, it is frozen or stiff, replace it. If the pump belt is broken
or worn out , replace it. Check the pump pulley
before you change the belt.
If
the motor isn't running, the lid switch is probably defective. If it is
so, the
washing machine cannot spin and may not function at all. The lid switch
is
inside the washing machine main housing near the door frame. Usually
you
have to raise or open the top or front of the washing machine depending
on the model to get to
the switch. If defective, you must replace it. Check it's continuity
when activated using an ohmmeter. A defective switch does not have
continuity when activated.
During the wash cycle, the lid was slammed from about 5 inches high. Now the machine is not coming...
(More)
During the wash cycle, the lid was slammed from about 5 inches high. Now the machine is not coming on. The fingertip faucet is the only thing that still comes on. I checked the breaker and outlet and they are fine. Is there some sort of reset or similar.
My washer just stopped in the middle of a cycle, there was no indication of any problems it just...
(More)
My washer just stopped in the middle of a cycle, there was no indication of any problems it just stopped
