Home | Microsoft | Xbox 360 Console | Whats wrong with my xbo...
Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Whats wrong with my xbox?
By novaksan on Nov 06, 2009
xbox was overheating it had 2 red lights that stayed on, I did the whole procedure with the heat sinks and the thermal compound, put it all back together and now there is 2 "flashing" red lights.
Solution #1
posted on Nov 08, 2009
Not Rated)
yourhelp
Rank: Wiz  Video Games  Expert
Rating: 82%, 75 votes
It means that it is overheating, if you are going to fix it yourself it is a good idea to get a video Xbox 360 Repair guide or send it in.
Go through it all again and make sure you have not missed anything.
Was this helpful?
Yes
No
Solution #2
posted on Nov 06, 2009
Not Rated)
repairtech99
Rank: Guru  Microsoft Video Games  Expert
Rating: 91%, 149 votes
One or both heat sinks is not making full
contact with the chips .
Open the unit back up and remove the
washers all of them their not needed.
just tighten the G.P.U. heat sink evenly.
not to tight.
The C.P.U. heat sink will also need to be
reseated if it got pulled , just push down
firmley on it and that should do it.
Rob
Comments:
Nov 08, 2009
- Bolting down the heat sink with to much force
will warp the board and will snap connections
under the G.P.U. due to expansion and contraction.
Warped 360 pc board are difficult to get a good recovery
on. evan with the proper re-flow equipment to re solder
the chips. just a little info
Rob
Was this helpful?
Yes
No
Solution #3
Not Rated)
Compurepair
Rank: Wiz  Microsoft Video Games  Expert
Rating: 84%, 783 votes
The x-clamp or repair kits, are quite efficient And effective.
But the actual Torque/Tightness of the Bolts Are very Important.
Usually when a 360 Overheats, with the original X-Clamps fitted. The motherboard Warps. The method is to :- repair the cpu/gpu heatsinks, apply a small amount of thermal Compound, And gently pinch-Tight the bolts. Then Run the xbox without the Fan Connected for a few Minutes to heat-up the Motherboard. then clamp the bolts a little tighter. these can be awkward, but with trial and error are usually repairable.
Also to be noted, are the older style heatsinks ( without Copper heat-Pipe ) are not as efficient as the newer or revised version.
Mike @ compurepair.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
I am trying to play a game that needs an update but half way through the update it stops and says... (More)
Answer
which wires do i use to connect up my xbox with my tv and laptop?
Answer
after adding a fan, a wire was pinched and grounded. The voltage regulator labeled 733 blew up. That... (More)
Answer
xbox just stopped,now showing 3 red lights help!!!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
