This coin op slide is mounted on a washing machine - the slide goes part way in but not all the way and sticks
SOURCE: empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
SOURCE: How to Reset a GE top load Invensys washer timer?
remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
SOURCE: coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
