Question about Nokia 6280 Cellular Phone
Sim Card not recognised
Boot the phone up and it no longer registers that there is a SIM card in the phone
  • cshead Jan 05, 2008
    Done all the obvious things. Clean, Change Sim / Contacts etc
    Looking for a technical responce.
    Thanks
  • kayla_bartho Dec 19, 2008
    what do i do when my phone dont recognize the sim card???
    Problem Solver:
  • 7 Answers
Be sure that the SIM card is put in correctly and make sure it is not broken.
Posted on Jan 05, 2008
6ya staff
SOURCE:
I have a HTC sense from boost mobile it doesn't have a sim card even though it has a slot for one but its stuck on HTC boot screen tried factory reset etc not working still gets stuck at HTC logo white...
Hi there
Just a thought but you mention that your phone doesn't have SIM card in it. Surely the SIM card is the heart of the phone, rather like a CPU in a computer, and during the phone boot process it will stall at a certain point if it doesn't find a SIM card to connect it to a phone network, in your case boost mobile.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Cell Phones
Phone not recognising sim card. Window pops up which says 'insert sim card or to view a demo of this phone first press Demo"
Sim contacts may be dirty, either on the card or phone.
remove sim card and GENTLY rub a pencil eraser on the contacts to clean, then test. If you can access the contacts on the phone, do likewise. If not, then you'll have to use an Ether based cleaner, Like electrical parts spray ( available from your local auto parts store) .
be careful not to spray too much into the phone, as once the spray gets inside it takes longer to evaporate. You can counter the time by using compressed air to speed drying of the phone interior without taking it apart.
Hope this helps!!
Nov 28, 2013 | Sony Ericsson Black Silver Cedar J108i...
I have a Samsung Galaxy Note. Suddenly, it does not recognise any SIM card. When I try to make a call, I get a message 'Not Registered on Network'. I have also notices that when I hold the power button, I...
More than likely your IMEI number is removed or missing. Dial *#06# and if it isnt displayed or says null then thats why.....or could be you need a new sim card reader but id bet its the IMEI number removed. Thats what i am dealing with now.
Aug 09, 2013 | Samsung Galaxy Note N7000 16GB Unlocked...
"Insert SIM" is shown when SIM card already present. How do I get SIM card to work or be recognised by the phone, OR how do I get the info off it if it's damaged?
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Aug 13, 2012 | Cell Phones
Iphone wont recognise sim
when you upgrade to ios 5 its no longer jailbroken and therefore your sim isn't being recognize. as probably your iphone is locked to at&t or verizon while your sim is from a different company then the lock.
Dec 21, 2011 | Apple iPhone 3G
I have a sony ericsson t715 mobile i think it is unlocked because when i insert the sim it says unactive sim.i need the unlock code for my sony ericsson t715 if my phone is locked if not please then can...
Hi if the phone is saying in active sim then this means that that sim card can no longer be used its either not been used for ages so the network have turned it off or it has been canceled all you need to do is get a sim card that the phone accepts if your not sure what network the phone is locked to then take it into any phone shop and they will tell you for free what network then phone is locked to and you can als get a sim card from them.
once you have a working sim card you will be able to use your phone, if the phone was locked it would say sos only or emergency calls only so it sounds to me like the sim card is no longer in use so getting a new sim card will solve your problem.
if it is a new sim card then you will need to call your service provider and register the sim this will then work in the phone as long as the phone will accept that network.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 28, 2010 | Cell Phones
Nokia 6500 slide sim card registration problemit normally says sim card registration failed immediately i on it
Hello
There are two things causing this problem,either your phone is not registered to the Sim card's network or your Sim card is corrupt
To find out where the problem has come from,you should try another Sim with your phone, if the Sim does not work then the phone is registered to a particular network and no other Sim card will work on it.
If you try another Sim card and it works then your Sim card is corrupt and you should replace it.but to be double sure,test the Sim card on another phone to see if it works,if it does then your phone is not compatible with the Sim card's network but if it does not work then your Sim has to be changed
thank you for visiting fixya
Jul 24, 2010 | Nokia N70 Cellular Phone
Sim card not recognised
Try inserting a different Sim card and check if it recognizes. If not you need to replace the sim card plate in the phone.
Jan 13, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Nokia 6280 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
