To connect the SD memory card to the computer you need a USB memory card reader. Plug the SD memory card into the USB card reader and then plug the card reader into the computer's USB port.
The computer will see this as an external memory card, you can then click on this memory card (it maybe the D or E or F drive) and select the music files from your computer then copy and paste your music files to this memory card. I presume the music files you need to copy are MP3 or MP4 files.
Was this helpful?
Yes
No
Popular Solutions for Lexar Professional High-Speed
Memory Card from camera damaged, so camera will not read. Help?? The plastic casing was slightly...
(More)
Memory Card from camera damaged, so camera will not read. Help?? The plastic casing was slightly damaged when stuck in card reader.
since i got this memory card it's gave me problems, since i have a LG CU500..but i found a way to...
(More)
since i got this memory card it's gave me problems, since i have a LG CU500..but i found a way to get around that tho annoying. My current problem is, i was going to put sum files from it on my laptop. I put the card in the adaptor that fit the size needed, but it keeps asking to format which my card already is. If i open as portable device it opens but says theres zero files on it..just like it does with the phone sometimes. Is there any reason for this or do i really just need to get a new card?
