I see a red light like something is red hot behind the back panel in the freezer. I removed the panel and I see a coil with 2 clear tubes that have some type of spiral metal inside. There is 1 midways of the coil and the other is at the bottom. Only the bottom one is getting red hot. What is this?
Comments:
Nov 06, 2009
- Solution #1 was very helpful and the heater shut off. I had unplugged the refrigerator just in case something was wrong and I have plugged it back up but I can't hear the compressor turn on. All the lights are on but I don't hear the unit cooling. Is there a reset button?
Those are the defrost heaters and glows red hot when defrost action is active. It should turn off when defrosting is complete or when the temperature is about 46 degrees Fahrenheit. If it does not turn off, the freezer will not function properly or it will be warm than normal. Have the defrost sensor assembly checked by a qualified technician.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
THANKS!!!! Nov 06, 2009
" - joshuae_jone
when it clicks cond fan trys to start if ispin blade it will run if i try to use water or ice...
(More)
when it clicks cond fan trys to start if ispin blade it will run if i try to use water or ice dispeser it shuts down could this just be a bad motor or is it the mother board difference of about 100 dollars in cost
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of...
(More)
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came intermittently. Now it is non stop. The ice machine still produces ice. Just doesn't dispense.
I have a 6 yr old GE that works fantastic except that it will go along and then just stop cooling....
(More)
I have a 6 yr old GE that works fantastic except that it will go along and then just stop cooling. then, after a while, it starts cooling again. If I put an ice cude on the freezer shelf, it will be there for days sometimes, then it's gone. But the Freezer is ice cold again. we noticed it when all the sudden the food was thawing out in the freezer, then it would work fine for a week or so, then do it again. Any ideas??
