Home | Maytag | Neptune FAV6800AW Top Load Washer | Machines is off bal...
Maytag Neptune FAV6800AW Top Load Washer
Problem for Maytag Neptune FAV6800AW Top Load Washer
Machines is off balance and moves across room
By loriandfr553 on Nov 06, 2009
machines is off balance and moves across room
Solution #1
posted on Nov 06, 2009
Not Rated)
FAV6800AWDIY
Rank: Wiz  Maytag Expert
Rating: 97%, 15 votes
Hi loriandfr553,
You are in the FAV6800AW forum. Is your machine model a FAV6800AW or FAV9800AW? If so I can help you DIY or give you enough info to control service cost. If your machine is the above type I feel you have lost Tub Displacement Sensor input to the control board I discuss this scenario at this post.
The Tub Displacement Sensor should signal the Control Board to terminate the spin cycle. Try the below test to check the TDS sensor for the FAV6800AW or FAV9800AW and post back your results. Disregard my post if your machine is not the above model Maytag TL.
Good luck Rich aka dh1200s.
Some handy links; the Service Manual for reference. Sears Parts Direct for reference
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 for the details.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine and we need to look at other issues. Has your machine faled in spin cycle with dc or UC error codes in the past?
Was this helpful?
Yes
No
Solution #2
Not Rated)
lilhelper
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 44 votes
This can be cause by having an off balance large or small load. If there has been an off balance load, this could indicate that you have also broken a strut. There are two located inside the machine that support the front and back of the tub assembly. The other possible cause of this is that you floor or leveling legs is set improperly. These struts are a slightly hard to replace as they require lifting the tub to set them into the top cabinet strut holder. and can be replaced at relatively cheap cost (around $60.00 each). In order to properly diagnose it, a technician would have to inspect it. Hope this helps
Thanks.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune FAV6800AW Top
Questions and Unsolved Problems for Maytag Neptune FAV6800AW Top
Do you recommend Maytag Neptune FAV6800AW Top Load Washer?
Answer
Answer
my top loader will not hold water it keeps draning out!!
Answer
my maytag washing machine stop working totally mid cycle. I'm not getting anything when I turn and... (More)
Answer
My Neptune TL is not completely draining. I've got the tub out but am having trouble getting the big... (More)
Answer
I have the Maytag Neptune MAH8700 series. I keep receiving the E3 error. It seems to happen just... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag Neptune FAV6800AW Top...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14736
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
