Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LG refrigerator isn't cold but bottom freezer is freezing the food
When I unplug the refrigerator for a few minutes then plug back up the motor operates for a few minutes kind of loud then cuts off then I get a code on the door that is ER FF what does this mean ? Please help !!!!
  • 2 more comments
  • mjbyers May 03, 2008
    I had the same problem and had to have the refrigerator serviced.  Apparently the fan and motor that supplies cold air to the ice compartment had completely iced up (it's inside the lower freezer compartment on the upper left-hand corner and not user serviceable).  Ice had slowly built up around the fan and motor assembly and finally go so bad the fan just stopped and burned out the motor.  There appears to be nothing that can be done to stop the ice build up other than regular service about once a year to take off the panel and run the assembly under hot water to melt the accumulated ice.  Seems to be a serious design flaw with no workaround.  I hope this helps and would definitely steer others from buying this model.
  • Anonymous Mar 13, 2014
    The refrigerator cuts off and stay off. when you unplug it and re-plug it come back on and freeze. I think it is the thermostat.
    my Frigidaire professional refrigerator freeze down to o/ and cuts off and don't cut back unless u unplug it and replug it . I think its the thermostat
  • Anonymous Mar 15, 2014
    It does not have lock as LG refrigerators and hence my food is eaten by unwanted guests when I am not home
    Master:
  • 363 Answers
If you want to know more things about RSGold can go to this website www.rsgoldfast.com
Our service is the most professional and most secure and convenient
Posted on Dec 20, 2016
  • 92 Answers
Ff is fresh food may be the ff thermisor but i would first check the freezer back wall is it frosted up can you hear the fan in the freezer blowing the air up to the ff section
Posted on Feb 10, 2008
Freezer not freezing but still cold
you might have ice on the coil in the back of the freezer under the cover. move your food to a cooler. eat a lot of frozen food then unplug the freezer and leave the door open for a few days this will melt the ice hopefully with no effort on your part. then plug it back in and wait a few hours to see if it gets cold.
Sep 14, 2014 | Refrigerators
Frigidaire refrigerator model # frs6r5emb8 wont get cold and freezer wont freeze. I replaced the filter and cleaned any and all dust out from the rear bottom of the refrigerator. Freeze wont get cold...
first off the freezer is cold but not cold enough?if the freezer isn't working right then the fridge is gonna be warm too,all it does is get cold in the freezer and the evap fan blows cold air into the fridge,that's it.i need you to do a few checks for me,open the freezer door,do you hear the fan blowing around,if not you could have a bad evap fan motor,next from the bottom up remove the second bin from the bottom and touch the back wall,do you feel any ice or snow on the back wall.if so you have a defrost problem,possible computer board,defrost thermostat or heater.let me know what you find.one more thing did this happen after you cleaned it or did you clean it to try to see if it would help?
May 15, 2011 | Refrigerators
My freezer seemed to have quit so I cleaned it out made sure the air flow was good and de-iced everything. Now the bottom of the freezer freezes but the top does not nor does the ice maker work. What do...
open the freezer door,do you hear the fan blowing around?it sounds like the evap fan motor isn't running and that's why it's cold on the bottom and not the top,you have to repair this fast or you'll loose your food in the fridge,the fan is what blows the cold air from the freezer to the fridge section.
May 07, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Good luck.
Apr 12, 2011 | Freezers
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Top refrigerator is not working, freezer is OK. When I unplug then plug it in again the indicator light for the refrigerator comes on but after a few minutes goes off, During the ime it is on there is a...
Your refrigerator gets its cold air from the freezer by way of a fan that transfers air past the freezer coils to the refrigerator. If the fan isn't working the refrigerator will not get cold. I your coils in the freezer are freezing up this will also stop the flow of air to the refrigerator. The first thing to check is the fan.
It definitely sounds like it has failed or is failing at least..
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Nov 06, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
Thanks
Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
I havs a side by side and the top won't stay cold or freeze.
Cold air being heavier than warmer air will settle to the lower levels. Check for fan motor operation inside the freezer section. If the fan is not operating you meed service. Also check for frost on the back wall of the freezer section. If the fan motor does not circulate the air frost will form on the back wall, also if the defrost system is not functioning.
Dec 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn Air ref/freezer not freezing/cooling
Take the back out of the freezer and check and see if the refrigerator is in defrost while it is cooling if it is replace the timmer, then check and see if the fan on the underside is working if not replace the motor this will cause the problem also.
If all that is ok feel the small line under the refrigerator ( high side) and see if it is hot while it is running if not check the freon in the refrigerator.
Mar 03, 2008 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
539 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
