We have a two year old Bosch 300 Nexxt washer. It has started working intermittently. It might...
(More)
We have a two year old Bosch 300 Nexxt washer. It has started working intermittently. It might finish one of every four loads. The rest of the time it just stops and sits there with no error code but the time remaining. The amount of time remaining can vary.
after initial setup, no water has entered the tank. at all. ever. i have done the regeneration...
(More)
after initial setup, no water has entered the tank. at all. ever. i have done the regeneration process but fear i may ruin something
I have a problem with the Bosch Nexxt 300 series where if i set it to a regular load it will wash...
(More)
I have a problem with the Bosch Nexxt 300 series where if i set it to a regular load it will wash for about 6 minutes then display a 002 or 003 error message-if I shut the dial off and then turn it back on it says 1.00 hour and then drops down to 54 minutes and resumes the wash cycle. Any ideas on how to rest this to get it to work properly? It also does not drain for the fabric softener on this cycle-it will with warm or hot water. Thank you
