One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it. You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE. Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Comments:
Nov 06, 2009
SPECIAL NOTES
USB flash drives can fail for no apparent reason. Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear. Known as "The Click Of Death"
my 500 western digital does turn on but when I have it connected ti does not register at all and I...
(More)
my 500 western digital does turn on but when I have it connected ti does not register at all and I hear a clicking sound every few seconds.
When i try to retrieve files from mt my book essential external hard drive i get a message that the...
(More)
When i try to retrieve files from mt my book essential external hard drive i get a message that the file coulnot transfer because it could not find a metadata file
My external hard drive will flash a light for a while then go away and flash again quickly when I...
(More)
My external hard drive will flash a light for a while then go away and flash again quickly when I plug it in. The hard drive will not boot up or load any of my data and my computer will not read the hard drive. what does this mean? And how can I get the hard drive to boot up? It will very rarely after like a month then when it shuts off it wont turn on again.
I have Windows XP. I cannot access or see the files directories on my My Book 500BB. In "My...
(More)
I have Windows XP. I cannot access or see the files directories on my My Book 500BB. In "My Computer" the Mb Book icon no longer is displayed, although a generic disk icon is displayed. When right clicking on the generic disk icon, Properties show no available space and no files.
