GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Problem for GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with...
Tube feeding ice maker comes off
By rosierowe94 on Nov 06, 2009
ice stops being made, then freezer fills with water which freezes because the pipe becomes dislodged
Solution #1
posted on Nov 06, 2009
Not Rated)
jackfrost555
Rank: Guru  Refrigerators  Expert
Rating: 92%, 77 votes
Good day,
Common problem. Remove ice maker, and make sure tube fits all the way to the rear and seats properly.
Then reinstall ice maker and telescope front part of file tube until it fits into ice ice maker properly. (retaining clip in place).
For the cost, a new fill tube makes sense. Also.........
If the water valve leaks slightly after shutting off during a fill cycle, a plug of ice will build up inside the the fill tube, pushing it off on the next fill cycle. Requires installing a new water valve.
Was this helpful?
Yes
No
Popular Solutions for GE Profile 26.6 cu. ft.
Questions and Unsolved Problems for GE Profile 26.6 cu. ft.
Do you recommend GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW?
Answer
Answer
Need to remove the doors on my GE TFX27PF side by side refrigerator to move it to the basement... (More)
Answer
My GE Profile Arctica leaks periodically...enough to cause damage behind the unit. Stops when I call... (More)
Answer
Freezer is cold but ice is melting and refreezing after it runs lower in the freezer
Answer
no water to ice maker. I think water shute is frozen, because I can get water to the door. I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile 26.6 cu. ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
