RCA R52WH73 Television
Problem for RCA R52WH73 Television
The picture on my RCA HDTV R52WH74 flipped out.
By matt_smolsky on Nov 06, 2009
The picture on my RCA HDTV R52WH74 flipped out. The red, greens and blues are outlining all the figures on the screen, there's a "sag" at the top of the screen. Everything seems to curve inward -- like the screen is being bent in the middle away from the viewer
Solution #1
posted on Nov 28, 2009
Not Rated)
ETERNALAA
Rank: Guide
Rating: 76%, 7 votes
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse it should be labeled that right on the board.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213 or you can goto radio shack and get a inline fuse holder and get the smallest glass fuse they have witch is .75amp witch is 500ma and all together cost about $5.00
7 RESOLDER FLYBACK CONNECTIONS or both ends of the inline holder simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
Was this helpful?
Yes
No
Popular Solutions for RCA R52WH73 Television
Questions and Unsolved Problems for RCA R52WH73 Television
Do you recommend RCA R52WH73 Television?
Answer
Answer
problem: watching tv from chest down with in terms of viewing actual cable channels
Answer
It seems the picture has gone bad on our our RCA 56" HD projection television. It is only 3.5... (More)
Answer
I have a RCA R52WH73 52" projection tv, I'm noticing that it's projecting "bigger"... (More)
Answer
3 (r,g and b) color lines in the background of the picture. The color alignment is PERFECT. The... (More)
Answer
The screen is saying searching for channel and I cannot cut the tv on or off without unplugging it... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
