Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power lights keep blinking
The power light keep blinking, but there is nothing on tv. The light only stops when i remove the power cord. help please.
  • s_adu Feb 11, 2008
    I have the same problem
  • Anonymous Jun 15, 2008
    the power light keeps blinking in a pattern, but there is nothing on the screen.. but the tv clicks when i hit the power button.
  • 319 Answers
The power light indicates a problem (usually) with an internal problem. Usually there is a pattern to the light. (for example 3 blinks then a pause, 3 blinks then a pause etc.)
A service tech can use the code to help determine the problem.
Posted on Jan 05, 2008
2 Suggested Answers
  • 14 Answers
SOURCE: sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Posted on Jul 25, 2008
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
Replaced the bulb and tried to turn tv on and a have a green blinking light that came on nothing else. Please help
Thas a very common problem for that model which happens when the power cord is unplugged. Failed caps on the DM and the Power boards wont re-charge when power is restored and the timer light blinks non stop. The V26 Chassis DLP DM / Power repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the capacitors and the CD with repair instructions.
Oct 21, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Standby light keeps blinking. tv wont turn on
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
May 07, 2009 | Televison & Video
Plasma problems
Well, it may be your power cord, check the cord for bare wiring which is the metal hanging out of the insulation rubber. If it is then go buy another cord.
Jan 29, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
STANDBY LIGHT KEEPS BLINKING
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Sony KDP-65S550 red light keeps blinking
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jun 28, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Sharp aquos lc -32da5u
Jun 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
2,105 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
