I turned on my receiver to find the light on the volume knob blinking, and no sound coming from my speakers. I checked all connections to find nothing out of place. The only ideas I got from the manual was to power down and then back up, or unplug for a minute and plug back in. No response from either attempt. I did notice however on the tuner setting only, with the volume 3/4 way up I could slightly hear some sound.
Any ideas?
Have the same problem, no sound, and the light blinking. When I hit the mute button the unit turns off.
Checked all connections, and the headsets get clicking sound. Finally, it smoked.
Posted by Guest on Jun 02, 2008
having the same problem any thing else to check other then the out put fuses?
Plug in some headphones as they are usually always active and see if you get any sound and volume control of them.
if not the switches may be stuck .
or the output fuses blown.
it gets sticky to work inside one of these without electronics experience and you can do more damage.
The fuses are about all you are allowed to fix.
Was this solution helpful? Show your Appreciation by rating it:
