Question about Altec Lansing ACS 45.1 Computer Speakers
No sound last week, the volume control on the speaker itself stopped working and the power lamp indicator went off. but the speakers still work as I was using windows media player although the volume setting is fixed, I cannot increase or decrease volume using the controls on the speaker. today, no sound comes out at all. what could be the problem? can I still have the speakers repaired? thanks
  • rymohn May 01, 2008
    Genius:
  • 1,067 Answers
See if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Posted on Jan 09, 2008
6ya staff
SOURCE:
I have altec lansing speakers set up with my PC running XP. Worked great until last week one of the speakers, (right I think) stopped working. Yesterday no sound at all from any speaker except a hum.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 16, 2011 | Altec Lansing Multimedia Computer Speakers
My speakers stopped working. The yellow light on the volume control is went out. I have checked to make sure everything is plugged in properly and that the power is in the "on" position.
> the light went out
Either the light itself is broken, or the speakers are not getting power, and so the lamp cannot light.
Try the speakers in another computer.
Or, buy a replacement set of speakers.
Nov 12, 2010 | Logitech OEM S220 2.1 Speaker Black...
Worked last week computer crashes now restored speakers don't work now. another set of speakers work. &35's won't work on a different computer, Powers up clicks when plugged in but no sound /
You said, other speakers worked fine ono that pc right? And the speakers doesn't on other computers? Then surely the speakers are now defective. It might be the wirings or internal parts of the speaker. Check warranty of the speakers, if it is expired, then you have to replace the speakers.
May 25, 2010 | Boston Acoustics BA735 Computer Speakers
I've had the series 1 companion 3 for almost 4
Hi, This could just be a sign that your Speaker system is wearing out , and done its due...Also have you had any Power Failures or surge's Lately , if so then it could of damaged the Speakers aswell..
Hope you come right bud
Happy new year
Dec 28, 2009 | Bose Companion 3 Computer Speakers
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
Polaroid FLM-323B LCD TV with no sound
Same issue....went to bed last night Polaroid tv worked fine....woke up NO VOLUME>>>
Jan 13, 2008 | Polaroid FLM-3232 Television
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Altec Lansing ACS 45.1 Computer Speakers Logo
343 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
