Question about Airnet AER114 Router
Setting the router NAT to Open
I do not have any info on my router. It is a Airnet AER114 router. Not sure how to access it. Can you help?
  • 306 Answers
SOURCE: Setting airnet aer114 NAT to open for XboxLive360
whats your set up? how and what are you useing.
Posted on Jan 08, 2008
0 characters
1 Points
1- Using your Browser, Log on to your router (by normally typing in the address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
I do not know how to change my NAT setting to open on Xbox Live
First of all I would just like to cover the basics of strict and moderate NAT settings. For those interested, NAT stands for Network Address Translation and is used to prevent problems with information being sent over a shared network.
With the XBOX 360, Microsoft have defined three categories of NAT. These are:
1. Strict
2. Moderate
3. Open
You can see the NAT level for your XBOX Live connection by going into your
1. System blade
2. Network Settings
3. Test Xbox Live Connection
For you question on how to open your NAT setting follow the steps below:
1. Type the IP address of your router in a web browser.
2. It will prompt you for a user name and password once connected
3. After logging in you will have a control panel of setting up different settings in your router.
4. The IP address, and default user name/password are different on every route
Note: is a pretty common address for most routers.
5. Check the manual that came with your router for that info.
I also provided a few links below of password lists of different routers.
Click Here
Click Here
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
I just bought a the Zonet ZSR4134WE wireless router to help my Xbox live. After setting everything up my nat type for the xbox live was strict. i was going to try and open ports 80 88 3074 and 53 but im...
Xbox settings have a setting for automatic. This is the best setting because you don't have to enter anything. It is all automatic.
On the router, make sure Nat type says open.
Jul 19, 2010 | Zonet ZSR4134WE Wireless Router
How do i change my nat setting from moderate to open?i have a belkin g 54 router number fsd7231-4
I think you want the NAT open for X-box.
For this you need to open the router set up page.
Is there any computer connected to the router .
If not then you will need to connect the computer to the router.
Reduce the MTU settings to 1365
open the ports for the router.
Click Here for more info
Nov 27, 2009 | Zyxel P660HW-D1 Router
Won't let my iMac connect to internet using DSL modem, ISP wont provide IP address it is a dynamic address they say
Is there any other computer online through the same modem ?
iF yes then modem will not allow 2 computers to go online at the same time.
Only 1 computer can go online with the modem.
If you have a router then 2 computers will go online.
Nov 21, 2009 | Airnet AER114 Router
How do i change my NAT setting to open
On your router you can try to reduce the MTU settings .
If MTU is 1500 then make it 1365.
Also disable the firewall on the router.
You will also need to open the port number for the gaming Device.
You want the NAT open for the X-box or Play station ?
For this you will need to access the router set up.
After opening the ports , power cycle the router.
I hope the following link will help you.
Nov 12, 2009 | NetGear WGR614 Wireless Router
How to Open NAT?
Look for a setting like "Virtual DMZ Host". It's hard to tell for sure without knowing the make and model of your router.
Jan 14, 2008 | Dell TrueMobile 2300 Router (000001)
Jan 06, 2008 | Airnet AER114 Router
Nat settings on netgear wgr614 wireless router
Hello --
Most NAT settings can be found, on modern routers, under the WAN setup of the router interface. Normally, it is set to Secured with the option of setting it to Open. Click Open and apply changes, giving the router a moment to reset the software and re-broadcast transmissions.
This comes secured for public consumption because the normal consumer would not create a WAN (wide access network) at home. However, gaming consoles (PS3 and Xbox 360) require this because of the P2P hosting that most online multiple-player games require. Setting it to Open full-duplexes the transmissions without restriction (since gaming console connections are "supposed" to be secure anyway).
After you've set the NAT settings, restart the gaming console, test the 'net connection and confirm it is reading your now Open NAT settings.
Oct 15, 2007 | NetGear WGR614 Wireless Router
Airnet AER114 Router Logo
100 people viewed this question
Top Airnet Routers Experts
 C. Dante
C. Dante
Are you an Airnet Router Expert? Answer questions, earn points and help others
