Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell e173fp monitor power
Monitor powers up and shows a picture and then goes black. Will do it each time you push the power button on the monitor.
  • 6 more comments
  • Anonymous Feb 02, 2008
    Hi
    yes I have a very simular problem.The screen goes black but the green
    light is still on, if i switch it off and on again the sreen goes on
    for about 1 second and then goes out
    Any idea's
    Cliff
  • Buddy Clements
    Buddy Clements Mar 05, 2008
    I to have a Dell Monitor that is having the same problem
    I have tried all suggestions . Any other solutions?
    IE: Transistors , Connections, Visible over heating.
  • Anonymous Jun 14, 2008
    Hi
    yes I have a very simular problem.The screen goes black but the green light is still on, if i switch it off and on again the sreen goes on for about 1 second and then goes out
  • Anonymous Jul 13, 2008
    I was really glad to find this article . I did some hobby electronics as a (german) radioamateur years ago... and have forgotten a lot. But still able to hold a soldering iron and use a multimeter... I tried:
    I have a DELL 173 FPb monitor.
    I replaced the two transistors C5707 ... the monitor worked... and an hour later it I had the problem again: Green light on, screen dark after 4 seconds. Diagnosis: The substituted two C5707 failed again. In fact, both had a shortcut.
    Before substituting them again, I would kindly ask your advice concerning the hfe-problem:
    Is it a good plan to substitute all four C5707 transistors (hoping they have nearly identical hfe values) with transistors I can get at a local store... or would I have to try to get them from DELL (hoping they have "better" hfe values. At a first phone call in Germany, DELL didn't want to deliver the transistors to me as a private person.
    About the capacitors: Could you give me a hint which capacitors are suspect to fail and are maybe to be replaced even if they still seem OK? Where are they situated on the board ( part number?). I have only a good digital multimeter available, no meter to measure capacitance.
    Best regards, Martin
    Best regards
    Martin
  • tim from tas Sep 28, 2008
    I have the same problem and when I checked out the lcdrepair.com link it states:
    Bad Inverter Board Symptom: No Display ( No Picture) on screen but Power Indicate light stays on green.
    Or Screen Flickering.
    Bad Power Supply Symptom: NO POWER, No Indicator lights are green on front panel.
    So it is clearly not a bad power supply as it starts up ok. So from the above choices it indicates bad inverter but I wonder if it is more a logic problem considering it starts up as normal and then drops out? after about 30 secs.
  • Anonymous Oct 03, 2008
    I have a dell F172FP monitor, light is green, monitor is black. It started by flickering and you could move it around and it would come on and work. But, now it is just black. Comes on for about l second, then goes black. It is 5 years old. HELP
  • Jimmy McCorkle
    Jimmy McCorkle May 11, 2010
    How do you get the case open?
  • 32 Answers
These monitors are a pain to open up. The inverter circuit for the backlight is on the right side of the monitor when veiwed from the front, part is c5707(marked) or 2sc5707(actual part number) around $1, there are 4 of them, one or 2 usually fail. Sometimes this failure can cause damage to one or more of the corresponding transformers which can can be visibly be seen affecting(melted) the yellow wrap. Be sure to check for dry joints around the affected area as the boards are very badly made, primarily around these transistors and transformers or the fault could reoccur soon after the repair. The same fault occurs in the dell 19", part number is 2sc5706. I hope this helps you out.
Posted on Feb 26, 2008
I found one of these monitors in the trash, it came on with no picture the light was green, I found out it was the control voltage for the HV power supply, I tore apart an old VCR salvaged a PNP transitor and a resistor and hotwired it, the only downfall is the brightness doesn't adjust but I assume the resistor value would have affected the brightness, if I needed it brighter.
Posted on Oct 01, 2008
Hi there! I am new to the board.
Ozwog wrote "These monitors are a pain to open up."
Well, that's my impression to ;-) As I have same basic knowledge i electronics and I suspect the capacitor, I would like to open the panel. But these modern plastic panel has few screws.. and some secret to open it. Short, I did not find our how to open it. Does anybody have any hints for me how to open it correctly? Thanks!
Posted on May 23, 2008
Soory!! I have the same problem but I had changed the full part of invertor but the problem cannot solve!!!!!
Posted on Feb 29, 2008
Check the backlight and inverter
Posted on Jan 12, 2008
The backlight bad or the inveter board.
  • 46 Answers
Check out this link http://www.lcdrepair.us/Installation.html
There are instruction videos and manuals for that unit. They also sell a kit or the whole board.
Posted on Jun 21, 2008
    Problem Solver:
  • 9 Answers
I used a company that sells the entire inverter board at a very reasonable price. I installed a new board and then shipped my old one bad and had it repaired for a backup. Here's the web site;
http://www.lcdrepairparts.com/
These guys are great.
Posted on May 29, 2008
Computer monitor all black but power is on.
Check to see that monitor is turned on, power cord is connected. Check to see that video cable is connected to computer. Verify that monitor's power light is on.
If it's still black with power on, you may have settings that have to be changed on the monitor.
Go here: http://support.dell.com/support/edocs/monitors/E173FP/En/trouble.htm
Aug 03, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor comes on for a brief milla second then
hold the power button for 5 sec : if the picture appears replace the button. ELSE check the chimic capacitor if damadged replace with new
Jun 21, 2010 | Dell E173FP 17" LCD Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
I have a problem with a Dell e173fp monitor. On power up, the power LED goes green and screen flashes on once very dimmly, then goes black.
Look for shorted out transistors (4) (c5706/5707) in the inverter circuits, this is common problem, post back what you see so we can guide you further.
Jan 31, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor Screen goes black seconds after turn on-
I ended up fixing my problem, but I'm not sure what the solution is. I had some faulty electrical equipment that I was using to power the monitor (220V to 110V converter and a bad power strip) and I got rid of them. I was using the converter because I moved to Israel and I thought I needed to feed the monitor only 110V, but I now realize that the power cord for the monitor has a built-in converter that accepts 220V input. Now the monitor is plugged directly into the wall and is working fine. Try using a different power source (maybe the wiring or plug you're using is faulty). Good Luck!
Apr 21, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
1,300 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
