one handset goes to dial tone by itself and have to pull battery. put battery back in and it looks like it working fine then it turn itself back on again and buttons don't work + load speaker. Other handset is working fine. No1 has problem No2 is ok..
Check if the screw of the phone is not too tight, because the button might press by itself if it is too tight.
If the problem is not solved,what I do in a situation like this is to loose the phone and use cotton wool or soft brush to clean it with a little mentholated spirit, leave it in the sun to dry, after drying, allow it to cool a bit and couple it back.
You should not clean the screen with spirit, you should clean only the board and the keypad also. Just a little spirit and don't let it be too much. You can dry in any other heat apart from sun and don't allow it over heat.
the portable phones read "connecting" but never connect so that you can use the phone. The...
(More)
the portable phones read "connecting" but never connect so that you can use the phone. The digital recording device works fine. When the phone rings the handsets do not light up or display the caller id
