GE Tritonr XL GSD6260JCC Dishwasher
Problem for GE Tritonr XL GSD6260JCC Dishwasher
Won't drain
By kcecco on Nov 06, 2009
Won't drain
Solution #1
posted on Nov 06, 2009
Not Rated)
jan mczeal
Rank: Guru
Rating: 88%, 273 votes
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Was this helpful?
Yes
No
Popular Solutions for GE Tritonr XL GSD6260JCC
Questions and Unsolved Problems for GE Tritonr XL GSD6260JCC
Do you recommend GE Tritonr XL GSD6260JCC Dishwasher?
Answer
Answer
Hello. My dishwasher is not draining the water. The resevoir is full when the dishwasher is done... (More)
Answer
Dishes from my GE triton XL washer are coming out somewhat dirty and grimmy. Any suggestions?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
