I have a Canon PowerShot SD790 IS. The camera turns on, the lens comes out and that's it. Then it shuts down and the code E16 shows up. Can't seem to find anything on that code that tells me what the problem is. The cameras only 18 months old. Can you help me?
The error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly
extending or retracting such as, for example, when pressure is applied
to the lens or the area surrounding the lens while handling the camera.
The error may also be displayed if the lens unit/camera has been
subjected to an external shock, or if liquid,
sand or dirt enters the camera. This issue may also happens if the Battery is not fully charged.
In this case, charge the battery completely then try to turn on the camera. Furthermore, try resetting the Camera to the original factory settings. You may also try hitting the lens gently against your palm after turning it ON.
There is a red smear type blotch in the lower corner of my view window and it stays while I'm...
(More)
There is a red smear type blotch in the lower corner of my view window and it stays while I'm viewing pictures or taking them
When I use my SD790 in bright light the picture comes out dark now.. when I push the button to take...
(More)
When I use my SD790 in bright light the picture comes out dark now.. when I push the button to take the picture the screen goes from normal to dark. That is what the image ends up looking like ..DARK!! This is on Auto setting as well as manual. :( I love my camera but this is horrible! Missed a lot of good shots at Disneyland because it just would not work!!
My Canon Powershot SD 790 IS no longer turns on. I have recharged the battery numerous times, but it...
(More)
My Canon Powershot SD 790 IS no longer turns on. I have recharged the battery numerous times, but it still won't start up.
Lens is stuck out, makes clicking noise and then peeps and screen states Lens Error, restart camera....
(More)
Lens is stuck out, makes clicking noise and then peeps and screen states Lens Error, restart camera. But everytime I start it it does the same thing, what can I do
